Question about Genius WizardPen 4x3 (K941C001) Graphic Tablet
Blinking LED I receive defective Genius Tablet from my clients. There are some cases like drained battery, worned pen tips, loosed connection between the conductive pad and the circuit board and other related cases, I can fix it easily. In case there is blinking LED at the pad, I don't have any idea what I'm going to do with it and I have no more choice but to request new stocks in order for me to send new units to my clients. What do you think I'm going to do with my stocks of defective units?
  • 3 Answers
SOURCE: pen doesn't work
ok i had the same problem BUT i opened the mouse pen control panel and under info i unchecked the "support tablet PC feature" and to my amazement it worked. hope it works for you :)
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: How do I open the Genius Mouse Pen to change the battery?
there should be a button type deal on the side somewhere above the buttons. push that in and pull the two halves apart.
Posted on Jan 25, 2009
SOURCE: pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Posted on Mar 19, 2009
SOURCE: Genius MousePen 6x8 pen drags as if I'm holding down mouse button
Listen up kiddos! I had this same problem and I was troubleshooting....apparently you have to make sure you uninstall the old drivers first and delete the directory entirely, before reinstalling the software.
So, UNPLUG THE TABLET! This is the part that screwed me up... then go to start > all programs > tablet > uninstall. Run the wizard, restart, go to my computer > local disk drive > program files and delete the Genius Tablet folder. Then, install the drivers again, reboot, THEN and ONLY THEN, should you plug your tablet back in.
Posted on Apr 11, 2009
  • 6 Answers
SOURCE: Problem with g-pen 610
hi there... Good news.. problem solved.. i was facing the same problem like thousands of others. not able to install the tablet f610 on to my macbook pro.
the solution turned out to be simple....
i went to the genius site.. go to products... tablets.. and under there somwhere u will find dowloads link... just download the  driver that you need.. ..
it will work.
best of luck
peter dsouza
Posted on May 09, 2009
Manhattan 177405 graphics tablet LED blinking.
The LED light is supposed to turn on when the pen is not being used. When you press the pen on the tablet the LED will turn off, only until you take the pen off the tablet. I believe this is mainly for troubleshooting, meaning if you press the pen on the tablet, the LED stays on, and the PC doesn't take in Input. This means you have either ran out of battery or the pen has been damaged internally. I believe it also tells you the tablet is powered on, again, meaning if the LED does not turn on when you plug the tablet into your PC then the tablet may be internally damaged, or the cord may be broken.
As for me; the LED doesn't bother me. When you're drawing with the tablet you should be looking up at the screen, not the tablet. So you shouldn't notice the LED.
I am not an expert, but I have been using this tablet for quite some time. I hope this helped.
Jun 03, 2013 | Manhattan 177405 GRAPHICS TABLET...
My Genius Easypen i405X tablet keeps clicking when I hover with pen
Hello :) we have the same problem regarding the same brand and product. But I got mine working just a while ago.
Try this: Control Panel>Pen and Touch
under pen options, there should be settings regarding the pen buttons. Unclick the "use the pen button as a right-click equivalent"
hope this helps though although it's been a year XD
Jan 11, 2012 | Computers & Internet
My Genius Easypen i405X tablet keeps clicking when I hover with pen.
Since you got this just a few days ago, you should take it back to where you got it and talk to them about what is going on. There is a warranty and you don't want to void that!
Mar 06, 2017 | Genius Computers & Internet
Okay, My MousePen tablet connects fine, my computer knows i have it attatched, and it knows i tap it with the pen 'cause the little LED light blinks... but the mouse onscreen doesn't move. it knows i'm...
I have the same problem. It happens after I'm not using it for 30 minutes or more. I don't think it's the battery or the tip of the pen because I've bought it a week ago. The only thing that work's is restarting the computer. But I hope that it's not solution!
Sep 27, 2010 | Genius MousePen 8x6 (MOUSEPEN8X6)
Irritating Genius g-pen 560 problem
Maybe you should try to look at the settings and see if it says 'Pen tip' And if it says 'Nothing' Or something like that, Change it to 'Left click'.
Mar 28, 2010 | Genius G-Pen 560 (31100026100)
New pen not working...
Check if there is a syncronise button or connect button on both the pen and the tablet.
Sep 02, 2009 | Genius G-Pen 4500, 4x 5.5 4x 5.5 tablet...
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
Genius 8x6 tablet pen freezes
Try putting a new battery in it. Mine was having the same sort of problems, and they were pretty much entirely fixed by a new battery.
Apr 05, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
My pen wont respond on the tablet
No software aside from drivers are necessary. The Genius Tablet comes a configuration menu you can test. If you don't have this, you can get it for free from Genius' website.
You need to hold the pen close to the tablet to allow it to detect movement. I hold my pen <1cm from the surface. You may want to check the batteries.
Nov 27, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
Tablet Pen not working
I have a G-Pen 340 which i just bought and the pen isn't being registered on the computer. The green light isnt even flashing :( I dont know whats wrong with it.
Jul 27, 2007 | Genius G-Pen 4500, 4x 5.5 4x 5.5 tablet...
Genius WizardPen 4x3 (K941C001) Graphic Tablet Logo
98 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
lorenzo carolus
Level 1 Expert
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
