Question about Canon PC-920 Black and White Copier
Paper Tray will not slide back in
I have a Canon PC770. I opened the paper tray and now it will not slide all the way back into the copier (goes all the way except for the last 3 inches. I can't see that anything is broken, in fact - I can't see any reason why it won't slide back in.
  • 2 more comments
  • Anonymous Dec 31, 2008
    The tray will not slide in, even with the **** shell open
  • helenamorus Jan 02, 2009
    I just encountered the same problem - nothing stuck but tray will not go back in the final 3 inches or so.
    Did you resolve your problem?
  • Anonymous Apr 09, 2009
    After many attempts, it finally "slid" back into place and worked fine, until today when indicator showed paper was out - but --- this time the drawer would not come out. Incidentally, the machine had paper.
    Took the screws off the bottom, and although not able to completely removed the metal bottom, was able to pull it out far enough to allow the drawer to be removed.
    The "only" thing that could be seen was a heavy duty spring (about 7" x 1/2" diameter hanging down from the back of the machine to a point where it might touch the back of the paper drawer. Spring wasn't hooked to anything and couldn't find where anything was broken, so pulled out spring.
    Replaced screws on bottom, drawer slid in fine and now makes copies. Have no idea what the spring operated, but at least copies are running.
  • Toptech
    Toptech May 11, 2010
    Try opening the clamshell of the machine and with it open attempt to push the paper drawer back in. Let me know what happens.
Pull the paper tray out and see if any paper or anything is behind the cassette
Posted on Dec 19, 2008
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Why my canon mf4412 paper jam but nothing in it.... even though I'd tried to find it out...
The back inspection plate can normally be removed by sliding to the right and then it can be removed
Jul 31, 2014 | Canon ImageClass MF4412 Toner Black Repl -...
PAPER JAM ON THE LCD SCREEN YET NO PAPER. CANON IR2020
IF IT IS A 2 CASSETTE MACHINE REMOVE ALL CONNECTORS OF 2 ND TRAY BY OPENING THE
BACK COVER(LOWER SMALL COVER) AND TRY. IF SYMBOL GOES OFF SOME PROBLEM
WITH LOWER LEFT HAND COVER RECTIFY IT. YOU CAN USE MACHINE WITH SINGLE TRAY TILL THE PROBLM IS SOLVED.
Jul 18, 2011 | Canon C330D Copier
Hi Where do I load the paper in my Canon MX310?
The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals .
I hope this helps.
Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
I have a printer canon inkjet mp140 and i don't know how to insert the paper from the tray that is down or from the upside tray
Well, you should insert the paper "from the upside tray". Follow these steps:
Align the edges of the paper before loading it;
Open the paper support of "the upside tray" and pull out the paper support extension;
Open the paper output tray ("tray that is down");
Adjust the position of the paper thickness lever;
Load the paper in the auto sheet feeder with the print side facing UP;
Align the paper stack against the right side of the auto sheet feeder.
Pinch the paper guide and slide it against the left side of the paper stack.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a Canon MX860 wireless printer. There is a paper jam. The paper is all the way to the back of where the paper tray goes and I can't reach it. I do not see anywhere on the back of the printer...
Canon says:
  1. Power off the printer.
  2. Remove paper from the Rear Tray.
  3. Look in the Rear Tray area for an obstruction. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove the foreign material by hand, or with tweezers.
Sep 24, 2010 | Canon Office Equipment & Supplies
Cannon pc770 copier claims that paper is jamed in copier checked and there is no paper jam
Recommend you call to service, cose so many problems You may only in detail and attentively examine the sensors of the passing the paper. May be the whole paper has jamed in on fuser, in stove. There is else of the reasons, can be are covered by dust.
Mar 14, 2010 | Canon Office Equipment & Supplies
Canon PC770 - paper tray wouldn't slide in all the way
Thats right that spring help to counter balance the top,the pease of plastic is to keep the spring in place.There are 2 spings that support the top.That plastic is not so expensive but to install the new plastic and spring is a very big job and it can be expensive.It normally takes me 3 hours to replace.The mashine can work normally it is only a hassel when you want to replase the toner .
Jun 16, 2009 | Canon PC-920 Black and White Copier
Canon PC770 Paper Tray Does not Close Completely
After numerous attempts, the drawer finally slid in and worked --- until today.
New problem - drawer wouldn't come out and indicator showed the paper was out when machine had paper.
Removed screws from bottom of copier - couldn't completely remove the metal plate, but was able to pull it out enough to allow the paper drawer to be removed. Only thing that could be seen as potential problem was a spring hanging down the back that did not seem to be attached to anything. (heavy duty, about 7" long and 1/2 inch diament)
Removed screw, replaced screws in bottom plate - drawer slid in fine - turned on and ran copies just fine. Don't know what the spring was for - but copier is working for the moment.
Jan 03, 2009 | Office Equipment & Supplies
Canon PC-920 Black and White Copier Logo
114 people viewed this question
old marine
old marine
