Question about Acer Computers & Internet
How to replace broken power supply connection on an aspire 3680 series
  • 70 Answers
Im sure this is a laptop not desktop if im correct your looking at a new mother board or some body that is good at soldering asuming its the plug it will be solderd to the main board if its the power suply its self you can buy these on ebay
Posted on Nov 04, 2008
My Acer laptop is an Acer Aspire 3680-2762 series. I'm currently looking for batteries online, my question is does the battery have to be the exact 3680-2762 or can it be just 3680 series?
Here is website, try that. hope that helps
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-LAP0239(Other+Products).aspx?dsNavigation=Ns%7eproduct+Type%7c101%7c1%7c%2cN%7e27-4294953664-4294951616&Title=Acer+ASPIRE+3680+replacement++battery
Feb 11, 2011 | Acer Aspire 3680 Laptop
Power supply jack on Acer Aspire 3680 Laptop not macking connection. checked power supply and it is putting out 19.2 volts. How do I go about changing jack?
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot fix this yourself then I suggest you get a quote first.
Nov 03, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 laptop. Computer is not getting power
If the power adapter light is not on, even when not connected to the computer, you have a bad power adapter.
You can find additional troubleshooting tips here:
http://www.shopbysystem.com/blog/?p=21
Aug 07, 2009 | UltraLast ULAC3660L For Acer Aspire...
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Power Board Problem and Power Button Hinges Top Cover broken
It would be cheaper to have the power board repaired but the replacement is around $55 from ebay. I'd get a new moulding for it if its available or even if you got somthing plastic welded up.
http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-Power-Board-w-dc-jack-usb_W0QQitemZ120415274982QQihZ002QQcategoryZ158887QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps
May 06, 2009 | Acer Aspire 3680 Laptop
Power button from my laptop acer aspire 3680 is broken
their are many people who sell laptop parts on eBay, I suggest looking there.
Apr 20, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
Acer 3680 ac pin broken
That's really not advisable. At our shop we do socket repairs, I suggest finding someone local who specialises in laptops and asking them to replace it. You can get the sockets on e-bay, etc, if you wish to try it at home, though I don't advise it.
Don't forget to take static safety precautions!
Aug 19, 2008 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
