Keep getting harddrive failure when booting up ! is the hd finished or could it be cable ?
  • MAINAMN
    MAINAMN Nov 05, 2008
    Thanks guys, I will give it a go.
  • 70 Answers
More likely to be the hdd
Posted on Nov 04, 2008
    Master:
  • 409 Answers
Goto http://www.grc.com download spinrite and give it a go. It may recoverthe disk for you. Or repair it enough for you to get your data off.
Acer 5100-5022 laptop won't properly recognize any harddrive
Sounds like the battery for BIOS is bad and the system is loosing CMOS data or the CMOS circuitry is bad.
Aug 20, 2012 | Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
I turned laptop on and get this message over and NVIDIA Boot Agent 249.0542 Copyright (C) 2001-2005 NVIDIA Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: media test failure, check...
your harddrive is either failed or your harddrive master boot record is corrupt and you will have to reinstall windows or the linux you used
Dec 14, 2010 | Computers & Internet
When i turn on the laptop computer, a message appears: primary hard disk drive not found, fixed optical drive not found. No bootable devices: strike F1 to retry boot;F2 for set up utility. I tried but...
Your BIOS is looking for a drive to "boot" from and does not see your harddrive or CD-rom.
You may have a harddrive failure or bad drive controller.
One way to see is to load your operating system disc in your CD-rom and see if the computer sees the drive and boots up. If it boots, try to locate your "C" drive. If you can't locate the harddrive, it's a good bet it's damaged.
If the CD-rom doesn't boot, it is most likely a bad drive controller or cable.
Dec 30, 2009 | Computers & Internet
Giving me messages about hardware failure and disk failure and telling me my hard drive isnt attached... getting the blue screen saying dumping physical memory then it tries to restart but wont boot all...
1st solution...
remove all power / power cables / batteries then keep pressing the power on button on the PC, ON - OFF, repetedly for some time WITHOUT POWER...put back the power cables...switch on....does it work ?
else
do this....
let the machine boot normaly....does it run checkdisk...if it runs chkdsk let it run....then if it boots after chkdsk is finished...it will show some erors...ignore the errors
else
do this
lf it boot from HD..after the machine boots before u get the blue screen press F8...do u get a selection to boot in Safe Mode...if yes..then chose that option....
let it boot in Safe mode...
once u get the desktop....
go to Start / Run / type..cmd..in the rectagle white box.
u should get a black window...that says "C:\Documents and Setting\Administrator or the user name>
there type cd..(CD followed by 2 dots)
again type CD..
it will take u to c:\>
there type
cd windows(type CD leave 1 space and type windows)
it will take u to windows directory
it will be some thing like this
c:\windows>
here type chkdks
let the chkdsk utility run....
guess it should solve ur problem...
else let me know...we can work on plan B
Dec 25, 2009 | Compaq Evo N610C Notebook
I have a refurbished Compaq Presario V2555us. It's a few years old, but has been a great laptop. It previously belonged to my girlfriend and the motherboard fried, so they sent it off for repair (this was...
The media test failure and the clicking sound from the hard disk indicated that the hard disk has failed. To get the laptop goining again, you need to replace the hard disk and install Windows on the new hard disk.
Jun 06, 2009 | HP Compaq Presario V2555US Notebook
My problem is my mainboard being a m2n mx se plus [replacement board] is only a two days old.When I ripped a cd to my 2nd harddrive it came up with following Delayed Write Failure and then later on this...
Check your second harddrive. First check its connection try to reseat it. Secondly, maybe its failing and somehow messing your CPU to boot up. You could try to disconnect your second harddrive for the meantime its power connector and interface cable. Then boot up with only your 1st drive where your OS is installed I suppossed.
Boot up, if this boot with no problem, 2nd harddrive is failing.
Apr 04, 2009 | ASUS P4V8X-X Motherboard
I have a acer aspire 5520 and it comes up with NVIDIA Boot agent 249.0542 copyright (c)2001-2005 NVIDIA corporation copyright (c)1997-2000 intel corporation PXE-E61: media test failure, check...
i think your harddrive got a problem.Maybe the hd are defect.Go to the bios(press `del `when start up)Than look if you can see the hard drive.
Dec 01, 2008 | Acer Computers & Internet
My laptop says a disk red error occurred and will not boot up it goes in circles asking for restarts and says the same thing also iam getting this message as well PXE-E61 MEDIA TEST FAILURE CHECK...
"PXE-E61 MEDIA TEST FAILURE CHECK CABLE"
This means that the motherboard and harddrive are not communicating correctly, there is no data cable to connect the harddrive to the motherboard on a laptop the harddrive connecting plug is soldered directly to the the motherboard.
Either your harddrive is dying, or your motherboard has gone faulty. Laptop repairs are quite involved, if you are not familiar with taking laptops apart I would suggest you get profesional help with this problem.
If you want to have a go yourself I can point you in the direction of websites I use when doing laptop repairs.
Sep 10, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
