Question about Siemens Computers & Internet
Wireless internet not working contacted perlico and they said that lan port was not open
  • 70 Answers
Try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Posted on Nov 04, 2008
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I have got username(admin) password)1234) wanting
Please connect the Netgear Router to your Laptop with a Ethernet cable.
In order to connect Netgear Router to your Laptop please follow these steps:
STEP 1 : If you look at back of router there are 4 LAN ports that are together and 1 WAN or Internet port which is alone. Connect the Internet cable ( provided by your Internet Service Provider) to WAN or Internet port of router .
Now take another Ethernet cable and connect one end of the cable to any one of 4 LAN ports and connect the second end to your laptop. Now please turn on the router.
STEP 2: You can see Power, Internet, Wireless and one LAN port light there on the router. Now come to computer and try to open the router login page.
In order to open the router page , you need to open your Internet Explorer and type 192.168.1.1 in the address bar.Now it will ask for router login information .
Username = admin Password = password
If it doesn't work please try to check the IP address of your computer ( In order to check the IP address of computer, Click on START menu , goto RUN and in RUN Window please type cmd. A black window pops up under this please type IPCONFIG and check the ETHERNET adapter IP address.
Now try to open the router page using this IP address.
STEP 3: Now on the router page you can see number of option on the left side. In order to change or secure the router for wireless connection please click on WIRELESS SETTING option under BASIC SETTING.
Under the SSID : type the name for your wireless network ( of your choice) CHANNEL : it should be 11 or 6 . Security : select WPA-PSK and under key please type any password of your choice ( it must be 8 characters atleast)
Please save the setting.
STEP 4: Now unplug the Ethernet cable from your laptop. Under the wireless networks , you can find your wireless network name . Just select it and click connect on. It will ask for security key or network key please type the same password that you have created for wireless setting.
Now it will connect you to your wireless network that is secured now.
Dec 09, 2010 | NetGear WGR614 Wireless Router
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Ps3 problem
- Physically connect the PS 3 to the Belkin router on one of the LAN connection
- Check the connection of the PS3 (if not connecting through)
- Contact your PS 3 manufacturer to gather the ports of the PS 3 and open it on the port forwarding of your router configuration page.
Note: you'll needing to allow the ports of your PS3 and IP address to the Belkin router.
Mar 07, 2009 | Belkin F5D7330 802.11g/b Wireless Adapter
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
Computers & Internet Logo
166 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
