Question about Insignia NS-DV2G MP3 Player
DEVICON.FIL This file pops up on my insignia mp3 player of it's own accord whenever it damn well feels like it. My whole mp3 freezes and the lights for the screen and buttons won't even go off_ I usually have to wait for it to run out of batt. b4 I can get it going again. It happened first after a month or 2 but is becoming more and more frequent. I'm fairly confident there may be another file other than devicon.fil- i"ve only ever seen it once and i wasn't able to copy it down but I'm worried there may be more files like devicon now... (**** for turning mp3 off during devicon.fil freeze*** I've found the only thing you can possibly do when the mp3 freezes is to just go as if to turn the mp3 off and keep holding it until it shuts off- I've only gotten it to work once and shortly after turning it back on- it will freeze again.) BTW I figured out how to erase all that junk on the device_ i apologize for wasting your time, I guess I was being lazy since I saw someone who had posted the same help request.
  • 170 Answers
SOURCE: Insignia Pilot doesn't always recognize music files
Okay...here we go!
1) Back up all your files on the player.
2) Re-format the player in windows as either FAT16 or FAT32 (no this will not remove the OS firmware).
3) Place your files back onto the player.
The volatile memory on these units can become corrupted if your USB connection is underpowered, split too many times, or has a few devices also drawing power.
This should fix your problem.
Posted on Jun 12, 2008
herodog909
  • 98 Answers
SOURCE: Won't turn back on - battery still alive
Connect it to your PC, right click on the device under My Computer. You should see the device. Right Click on it, and if you do not see "Format", then open it. There should be drives, such as internal Storage. Right click here. You should see "Format". This wipes the device completely.
Posted on Jun 02, 2009
  • 3230 Answers
SOURCE: I made the mistake of
First of all take a backup of your player and then format it.....
all the memory error goes by formatting the player ......
Post further comments for more information...
Good Luck!!
Thanks
Posted on Jul 18, 2009
male_28_cam
  • 1555 Answers
  1. My first suggestion is you take your player to a different pc install the driver over there and connect it after installing the driver. Let the plug and play devices do its work. Check whether your files are visible on that PC or not.
  2. Change the data cable you are using for a while and then recheck on different pc.
  3. If none of the above works even for browsing your file then follow the following
  4. Hit the player's reset hole on the side with a paper clip (or similar object) to reset the player. Check to see if the problem goes away.
  5. If the problem persists, restart your computer.
  6. Try another USB port.
  7. If the above didn't help, format the player by using the format option in your 'Advanced Setting', than try again.
  8. If formating doesn't help, try restore your PC setting to the last known good setting or restore point (Windows XP/Vista).
  9. Try uninstall WMP11, than reinstall it back with a full copy downloadable via Microsoft.
  10. Check whether the player shows up in 'My Computer', than try it on another PC (with WMP11 installed) to confirm that your player is still fine.
You are most welcome if none of the above works for you. They have been written specially for you in the pattern in which you shall troubleshoot kindly don't break the pattern. If at any moment you seem hesitant don't hesitate asking me. I'm available for you for another hour. Will be checking your comments every 5 minutes.
Mahendra.
  • 3 Answers
SOURCE: My Insignia MP3 player makes a soft, long beep noise and freezes.
i had the same problem i fixed it myself,on the back of the player there is a tiny black dot near the top of the battery cover remove this dot to reveal a small eye glass type screw remove the screw with an eye glass repair kit or a straight razor,gently remove the battery cover be extra carefull because there is a tiny wire attached to the battery on the bottom of the wire is a little plastic prong gently pull it off the player with your fingernail and then place it back on press power and your player should be working
Posted on Sep 14, 2009
What is a DevIcon.fil
That is a Microsoft format Icon File. It is used by Windows Media Player. Much more information can be found HERE.
Sep 15, 2010 | Computers & Internet
New update from Rhapsody, messing me up
I would recommend reinstalling the original software/drivers. You can find them here.
Dec 26, 2009 | Insignia NS-DV2G MP3 Player
Sep 04, 2009 | Insignia Sport MP3 Player
I made the mistake of following the advise to delete my digital files to make more room. Now my iriver Clix still tells me there is no room left to download but none of my music shows up on it. There are...
Good Luck!!
Thanks
Jul 18, 2009 | Insignia NS-DV2G MP3 Player
May 29, 2009 | Insignia NS-DV2G MP3 Player
Mp3 insignia
when the auto-play window comes up, click open folder to view files. Click-and-drag the files to the window that pops up when you click open folder to view files. Usually it is called what ever you name it. Hope this helped
Jan 16, 2009 | Audio Players & Recorders
Freezing
Whenever an Insignia mp3 player freezes up, hold the power switch for good 20 seconds to shut it off.
Jun 08, 2008 | Insignia Sport MP3 Player
Mp3 player freezes while synchronizing files
If its frozen for everything go to utube 4GB INSIGNIA PILOT (FROZEN)
Feb 26, 2008 | Insignia NS-DV2G MP3 Player
Player freeze on "Build library.."
the answer is to go to settings click on information and go to erase internal memory ....that is the way i fixed mine
Aug 17, 2007 | Insignia NS-DV2G MP3 Player
Sandisk e20
Reformat, disable auto-sync
Aug 07, 2007 | SanDisk Sansa e270 MP3 Player
Insignia NS-DV2G MP3 Player Logo
2,366 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
