Question about LG 42LC2D 42 in. LCD HDTV
LCD LG42LC55 TV switching OFF
I have the fault of it switching off every 20-30 minutes, and I have swapped the power assembly board EAY34797001, but the fault remains.
Any ideas?
The TV is a LG 42LC55
THIS IS CAUSED BY THE MAINBOARD AND NEEDED TO BE REPLACED.
Posted on Nov 30, 2008
Sharp LCD TV takes a long time to turn on
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2016 | Sharp Televison & Video
Sharp LCD TV Takes 20 minutes to warm up
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 12, 2016 | Sharp Televison & Video
Neither the remote or power on/off switch works to turn on
I'm assuming you tv doesn't turn on but you have the red light indicating power , it's possible you have more than a faulty switch , common fault is the power board has blown one or a few capacitors , you could try replacing the power board on the tv but some tvs will not start if there are other faults , namely faulty inverter , faulty power board , if the display is faulty , it'll be cheaper to buy a new tv
Sep 19, 2014 | Toshiba REGZA 52RV530U LCD TV
Lc-32d62u
Check its main digital processing board. It has the fault. May need replacement.
Mar 09, 2012 | LG 42LB5D 42 in. LCD Television
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Bush lcd wont switch on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter, or faulty LCD controller board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 05, 2009 | Televison & Video
Standby Indicator flashing SONY KD-32NX100UWhen I turn the TV on the TV goes straight into standby red light, I press the on button on the remote and the TV comes on for about twenty seconds then it...
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Nov 19, 2008 | Sony KV-35S42 35" TV
LG 42lc7d 42" lcd
Replace power supply and this should take care of all of you problems part number is EAY34797001.
Josh
Feb 09, 2008 | LG RZ-20LA70 20 in. LCD Television
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
LG 42LC2D 42 in. LCD HDTV Logo
454 people viewed this question
Computer Repairing
Computer Repairing
