How to connect projector to sky plus box using RGB
Hi folks i just bought acer 1160 model projector and want to connect to my sky box to it for best picture quality my projector has only vga,svideo inputs only . i tried scart to vga cable but msg comes on screen as connection not compatible ,any solution pls
  • bishy118 Jan 02, 2009
    is Acer x1160 compatible with sky and how does it be connected by scart
  • Anonymous Feb 17, 2009
    I have the x1160 aswell and im doing SCART to VGA...it does work but only in black and white
I have same problem as above can you advise please
Posted on Jan 02, 2009
Hi i have the same projector (acer x1160) and want to connect sky to it also i was going to go with scart to vga but if you say that donsn work then i might try to connect the 10 pin vga that is on the back of the sky box to the 15 pin vga on the projector i will let you know if it works.
Posted on Nov 21, 2008
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
May 19, 2009 | Televison & Video
Picture distortion
Hi!
That S-video cable...if it is longer than 1 meter you will get a poor picture. Get an component cable and connect your players thru that, that will improve thepicture 1000 times, belive me
This is the connectors back on your Acer
1 x RGB D-Sub 15pin
1 x Composite
1 x S-Video
1 x Component
And the component connector is way the best of them, its better that all of the together..if i may say so
Good luck
Nic
Mar 24, 2009 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Sky + to a Hitachi CP-X340 Projector
I would use the s-video connection even though I see word that the Sky+ box does not have automatic aspect ratio switching on the s-video output. You could also use an SCART to RGB cable but the picture quality will only be marginally read:un-noticeably better. Here is an s-video cable:http://www.rselectronics.com/Catalog/ViewPart.aspx?Part=CSV-06&MFG=QVS And here is the SCART to RGB: http://www.svideo.com/scartrgb.html
May 29, 2008 | Office Equipment & Supplies
Projector Problem- Screen appears Blue
Hi there
Press the source button on your Projector until it reads RGB.
If this doesn't work , right click on your desktop and go to properties - check that your seconadry screen is attached in your advanced settings.
Apr 26, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Acer PD726W
Hi there
You'll have to settle for the ordinary Composite input on the Projector.
You do get a scart to composite convertor from most good PC & AV shops.
Mar 27, 2008 | Acer PD726W Projector
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Connecting Sky TV to my projector
Which sky box do you have and which model projector. are you trying to use SCART or YUV or what.
Please describe the connector available on the sky box and the projector. if you dont know or they are not labeled nicely please refer to the chart in the link below and let me know what is on both boxes. I will do my best to reply with EXACTLY what cable you need and a good place to order it, US and UK.
Also let me know what distance you need to run.
http://h71028.www7.hp.com/hho/downloads/HP_connector_chart.pdf
Oct 10, 2007 | Office Equipment & Supplies
1,190 people viewed this question
jasbo
jasbo
