Question about Whirlpool Duet GHW9150P Front Load Washer
FRONT DOOR LOCKED - Whirlpool Duet GHW9150P Front Load Washer
  • 5 more comments
  • fobrien Dec 24, 2008
    I own an Asko and the door is locked tight and will not budge! please help! I have tried switching the washer on and off, have put the clothes through another cycle, but without success.
    some advice would be much appreciated!
    sincerely,
    felicity
  • Anonymous Jan 24, 2009
    It's locked up on me too! The door will not open!
  • dotterstrom Jan 26, 2009
    Mine is doing the same. It runs about half way through the cycle then all panel lights go off except for the door lock light, which starts blinking. We have run the cycle a few times but continue to have the same problem. We have not been able to open the door.
  • GypsySpirit Feb 03, 2009
    Help ... my clothes are being held hostage in my washer (Whirlpool duet)!!! The door is locked ... but the door lock light isn't on. The washer won't run because it doesn't recognize that the door is locked. It just "clicks" then gives the dl error. I've tried resetting it, unplugging it, disconnecting the contacts, beating on the control panel ... does anyone know how to mechanically get at the lock to open the door?
  • Anonymous Feb 24, 2009
    Mine too is locked but I can't get it to run a cycle. I've been have "df" codes forever but I guess the machine has finally had it. Would love to know how to access the door lock with the door locked shut. Anyone?
  • lrstro10 Apr 08, 2009
    after all the cycles are complete the door remains locked. I bypass this by starting the next load and hitting cancel after I hear the door unlock.
  • sayia May 06, 2009
    Door is locked and cannot be opened. I have tried the 3 sec button, but it still does not open. I can't see where you can removed the kick panel on the bottom, I don't see any screws that can be removed.
    President:
  • 1,294 Answers
First try to hold down 'end of cycle' for 3 seconds, try door after a minute or so after hearing a click, power shd be on. If not:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Posted on Apr 06, 2009
I have unlocked my door manually, now it won't start when I hit the start button, Power button works, but Start button just beeps at me. Help!
Posted on Sep 12, 2009
Yep, Gently pull the tab down about 1/4 inch or until a click is heard, worked great. I think my door is still slightly out of alignment (hanging a little low) causing the locking pin to drag and hang up.
Thanks for your contributions to this site
www.AlanKnightandCompany.com
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
How do you replace the regulator for the power window on the 2002 ford explorer
Regulator - Power Windows - Front Door
  1. Remove the front door trim panel as follows:
    1. Remove the front door handle bezel.
    2. Remove the front door window/lock control switch bezel.
    3. Disconnect the window/lock control switch electrical connectors.
    4. Remove the 3 front door trim panel screws.
      CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step.
    5. Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    6. Remove the exterior mirror control switch from the front door trim panel.
  2. Remove the front door speaker.
  3. Remove the interior molding.
  4. Disconnect the door lock actuating rod at the door handle assembly:
    1. Release the door lock actuating rod clip.
    2. Position the door lock actuating rod aside.
  5. Remove the front door weather shield.
    CAUTION Make sure the holes in the glass bracket do not become enlarged during the rivet removal process. If the holes become enlarged, the new rivets may become loose, resulting in clicking noise concern.
    NOTE Some vehicles may use rivets to attach the window glass to the window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill out the glass-to-regulator rivets.
  6. Remove the 2 front door window glass-to-regulator bolts or rivets.
  7. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets.
  8. Secure the front door glass in the full up position with tape.
  9. Disconnect the window regulator motor electrical connector.
  10. Remove the 4 window regulator assembly nuts.
  11. Remove the window regulator assembly.
    Fig. Exploded view of the front door and power window components-2005 Explorer and Mountaineer
To install:
  1. Position the window regulator assembly.
  2. Install the 4 window regulator assembly nuts. Tighten to 89 inch lbs. (10 Nm).
  3. Connect the window regulator motor electrical connector.
  4. Remove the tape securing the front door glass in the full up position.
  5. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets. Install the bolt and tighten the bolts to 62 inch lbs. (7 Nm), or install new rivets.
  6. Install the front door weather shield.
  7. Connect the door lock actuating rod at the door handle assembly:
    1. Position the door lock actuating rod into proper location.
    2. Attach the door lock actuating rod clip.
  8. Install the interior molding.
  9. Install the front door speaker.
  10. Install the front door trim panel as follows:
    1. Install the exterior mirror control switch from the front door trim panel.
    2. Position the door trim panel onto the armrest to engage the panel clips.
    3. Install the 3 front door trim panel screws.
    4. Connect the window/lock control switch electrical connectors.
    5. Install the front door window/lock control switch bezel.
    6. Install the front door handle bezel.
  1. Raise the front door window glass to the full up position.
  2. Remove the interior door handle.
  3. Support the front door window glass.
  4. Disconnect the front door window regulator motor electrical connector.
  5. Remove the equalizer bracket nuts.
    Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
  6. Remove the front door window regulator by removing the rivets and nuts.
  7. Remove the front door window regulator motor retaining bolts and then remove the motor.
    Fig. Remove the front door window regulator motor retaining bolts and then remove the motor-2005 Explorer Sport-Trac
To install:
  1. Installation is the reverse of the removal procedure.
  2. Tighten the regulator motor mounting bolts to 8 ft. lbs. (11 Nm).
Hope this help (remember rated and comment this).
Mar 24, 2010 | 2002 Ford Explorer
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
How do I replace the door lock actuator on a 1999 Mercury Villager w/o damaging the connecting rods and door track?
SECTION 501-14A: Handles, Locks, Latches and Mechanisms 1999 Villager Workshop Manual REMOVAL AND INSTALLATION Actuator —Power Door Lock, Front Removal
  1. Remove the front door latch. For additional information, refer to Latch—Front Door .
  1. Remove the power door lock actuator from the front door latch.
    1. Release the locking tabs.
go here too
http://groups.yahoo.com/group/villagerquest/
Sep 26, 2009 | 1999 Mercury Villager
2004 Camry front driver door lock will only lock/unlock with key, the remote and lock button locks and unlock all locks fine except for the front driver side door lock. You have to either use the key or...
Remove the door panel and reconnect the plug going to the front driver door lock or, if you can hear the motor trying to engage the door lock cam when you press the lock/unlock remotereconnect the door lock lever bar
Jun 09, 2009 | 2004 Toyota Camry
Driver's side door won't open in the cold
Power Door Lock Operation (Front Doors)
The front doors do not have traditional door lock actuators. They have electronically controlled door latches that will operate depending on the status of the door lock system. This status is determined by the front door modules and the last known state of the lock system. If the last known state is LOCK, the latches will not release when the door handles are operated. If the last known state is UNLOCK, the latches will release when the door handles are operated. The front doors are also equipped with red door lock status indicators. The front door modules will supply power and ground to the indicators to illuminate them when the lock system is in a virtual state of lock. The indicators will not continuously illuminate when the vehicle is locked. They will illuminate for approximately 5 seconds after a lock switch activation or after a door handle has been operated and the front door modules are in a virtual state of lock. For further information on the front door latches, refer to Power Door Latch Description and Operation .
I would assume they check for DTC'S - diagnostic trouble codes ?
DTC B3062 Front Door Key Lock Switch Circuit
• DTC B3067 Front Door Key Unlock Switch Circuit
DTC B3849 Exterior Door Handle Switch Circuit
The left front exterior door handle and right front exterior door handle switch signal circuits provide inputs to the driver door module (DDM) and passenger door module (PDM) when an exterior door handle switch is activated. These inputs allow the door module to detect a door open request. The door modules provide voltage to the door handle switches. If the door module detects that a ground is applied for greater than 30 seconds continuously, a DTC is set and the door module will ignore the door handle switch input.
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model and engine size . Under system click body & accesories .Then under subsystem click power locks . Click the search button then the blue links
Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen
Aug 10, 2017 | 2006 Cadillac STS
Broken exterior door handle,passenger sider ,sliding
Got this idea from mpvclub.com: Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
'93 Camry V6 problem with door locks
your power lock actuators are bad in the front doors.
Aug 20, 2008 | 1993 Toyota Camry V6
Whirlpool Duet GHW9150P Front Load Washer Logo
743 people viewed this question
Dan Webster
Dan Webster
Sal De
