Question about Toshiba 32A62 32" TV
Black rectangle on t.v. screen
The problem is on the lower half of the screen. While the t.v. is on a black rectangle appears on the lower half of the screen. The t.v. stays on in the background, with a 3 inch border around the black box. The box does not disappear at any point, even when the t.v. is turned off or unplugged.
  • jsevyc Dec 17, 2007
    lower half screen is black
    around 3 inches of inverted picture in the middle of the screen
    President:
  • 3,130 Answers
It sounds like you have the Text feature on the closed caption option turned on. your going to most likly need an original remote to turn this feature off as far as i know of. If you do not have an original toshiba remote to turn off the clkosed caption or in some sets you have to go into the menu to turn this feature off, maybe you can borrow one from a friend that has one or you can get one from http://www.remotes.com. Good liuck and let us know if you need more assistance
Posted on Oct 05, 2006
I have the same problem, but it was only on certain channels (5, 10) and i'm not sure of the company who make my tv but it has a D in a circle as it's logo - is it Direct? It was the cheap $120 19" tv. But, i took techman's advice (on this page) and turned off the closed captioning thing (which i never remember turning on, but OK) and it fixed the problem :)
Menu - Closed Caption - Off
Posted on Jan 13, 2009
We had the same problem and fixed it with the suggestions here. Although we thought we had went to the closed captions section before...We did again and there was the problem fixed it in two seconds.. It is defiantly on the TV original remote under Closed Caption.
Thanks
Posted on Sep 13, 2009
When that happens I press lightly the volume on the remote control and it dissapears.
Posted on Jul 26, 2009
The first response is correct. This is mainly with Toshiba televisions, although I do not know my model. You can also do it with the TV if you have certain models, but it's under the menu screen with only two options, the second of which is closed caption.
Posted on Jan 16, 2008
Black rectangle appearing in lower half of screen on 32" Aquos
did you turn off the close caption settings in the set up menu.
Sep 15, 2012 | Televison & Video
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Jan 24, 2010 | Vizio VX37L Television
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Jan 20, 2009 | Disney 13" TV
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Large Black rectangle on bottom half of screen
My mother-in-law had this problem on a Quasar for two years before she finally mentioned it. The rectangle is a text box for closed captioning or for a demonstation list of features, but without the text. I restored the factory presets and poof... problem solved.
Look in the manual and find how to restore the factory settings - it will probably be some weird combination of buttons that you would never guess. On her set, which has a built-in VCR, it was simultaneously pressing "play" and "FF" (on the set, not the remote) for five seconds until the set powered down. Yours will probably be something different but equally odd. That should get rid of the black rectangle. Then you go through the initial setup and you're back in business.
Jun 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Jan 10, 2008 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Black on lower half of screen
This type of problems and some OSD problems are occurs due to microprocessor over modulation. One option is there. That is if you have any child lock or keypad lock or frontpanel lock. First locked the system. Now check your problem arise. If it is not OK. Otherwise try to find nearby any radio frequency cable across in your tv. keep away that cablewire also. your problem solved. Even you get Call your nearst service provider..
Aug 23, 2007 | JVC AV32F577 32" TV
Toshiba 32A62 32" TV Logo
2,261 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
