Question about Crown CE1000 2-Channel Amplifier
Fault lights hi im a tech in south texas and some how i managed to get 3 ce 1000's in all at the same time, now ive been testing them for few days and they all work but channel 2 does not function as a bridged channel, but worksfine in stereo. they all have equal volume and no static or intermitten problems, non of the fans are coming on but i assumed its cause the cover is off and its pretty cold in my shop. crown hasnt given me a straight answer and alays comes back to the relays c-10335-5. and to make matters worse 2 of em are 98's and one is an 05. but they use different relays (05 has spades on top, 98s dont) im not an idiot (t least i hope not) and have a great amount of fixes and time under my belt.
  • bhrepair Nov 06, 2008
    ACTUALLY I FIGURED IT OUT ON MY OWN AND I AM RIGHT THOUGH I SHOULD OF KNOWN BETTER TO PUT IT ON HERE.I KNEW THAT ABOUT THE FANS AS WELL AND STATED THAT. CHANNEL 2 WILL NEVER WORK AS AN INPUT IN BRIDGED MODE ITS ONLY DESIGNED TO WORK LIKE THAT WITH 1. CAN U TELL ME WHY THE CE2000 I HVE RESETS AS IN POWER SHUTS OFF AND THE FAULTS FLASH WHEN U JUST TURN THE SWITCH FROM BRIDGED TO STEREO? CROWN DIDN'T KNOW.
  • bhrepair Nov 07, 2008
    thats the first ive heard of that and seeing as how the tech at crown didnt seem to care about it ill take it as tht they have run the circuts how youve described. which the 2+ and 2- just get changed to a diff position.
  • 4,234 Answers
I'm not sure what you mean when you say the channel 2 does not work in bridge mode. Bridge mode effectively turns the amp into a mono amp, thus there is no channel 1 or 2. The fans will only turn on when the heat is high enough, so that is not a problem. Please describe what you perceive as the problem with these and I'll try to help.
Thanks,
Dan
Posted on Nov 05, 2008
  • ABRsvcs Nov 06, 2008
    Any change from stereo to bridge mode should only be done with the amp in the OFF position. Because the switch changes the circuit configuration and offsets, any residual voltage could cause damage. Fortunately for you, the protection circuit kicks in to prevent it. I would not rely on that forever though. In general practice, only change modes in the power down condition. Also, these units usually have draw-down resistors to drain the power supply on power off. Give the unit a few minutes between mode changes as well.
    Dan
Gongly soft ice cream machine won't work. Beeping sound when power is turned on. What is the problem?
manual control soft ice cream machine, View carpigiani ...
gongly.en.alibaba.com > Product Categories > Soft Ice Cream Machine
manual control soft ice cream machine,US $ 0 - 1000 / Unit, Air-Cooling, CB, CE, ... Brand Name: GONGLY; Model Number: BQL-838; CERTIFICATION: CE/CB, ...
Machine glace italienne www.gongly.eu - YouTube
? 6:48
https://www.youtube.com/watch?v=D7c2Hiwi6FQ
Jan 3, 2011 - Uploaded by TvSTORE
Machine glace italienne www.gongly.eu. TvSTORE ... Jin Li Sheng Fry Ice Cream Machine Fried Ice Cream Machine Fry Ice Pan Machine ...
Hot Sale Jin Li Sheng BQ322 BQ332 Soft Ice Cream ...
? 1:14
https://www.youtube.com/watch?v=ChUllkdJMlc
Jan 14, 2016 | Ice Cream Makers
I have a '99 dodge grand caravan se, while in park the abs light came on, the battery light came on, and the check engine light has been on,
Looks like you have a few issues there.
1. The battery warning. This is indicative of a weak battery and if your battery is 3 years old or more I would replace it.
2. If you have a weak battery this can trigger other warning lights in the vehicle, typically the ABS warning but sometimes other warning lights as well depending on the electronic features in the car. If you replace the battery this should correct the battery warning and most likely the ABS warning if both of these warnings appeared at the same time.
Normally, once the ABS warning is displayed the anti lock braking system(ABS) will be shut down. Whilst your braking will be normal, if you brake too hard and lock up your wheels on a slippery road there is no ABS assist to prevent the brake lock up which you have when the system is working.
3. If the alternator on the engine is not generating sufficient power and thus not charging the battery at all, or very little, you will likely get a battery warning light. I don't know if your 1999 vehicle has a warning light to indicate a faulty alternator or not.
4. Check Engine Light.
You suggested the CE warning has been showing up for a few days and before the battery and ABS warnings popped up.
The CE warning can be caused by dozens of different engine issues.
The vehicle needs to be scanned with the appropriate scan tool to see what fault codes the onboard computer is generating because if you have a CE warning light there will be fault codes generated 99% of the time.
Once these fault codes have been pulled the mechanic can start to diagnose the cause of the problem or problems. Each engine fault code your car's computer is generating can be caused by different types of problems so it is important that they diagnose the issues correctly. Otherwise your Check Engine light will remain on as long as the causes are not identified and fixed.
Dec 29, 2015 | Dodge Cars & Trucks
Dell beep codes
If the system is beeping thrice in continuous loop with POWER LED blinking then it could be due to :
1)Chipset Error (North and South Bridge Chipset, DMA/IMR/Timer Error for Intel platform); Chipset Error
2)Time-Of-Day Clock test failure.
3)Gate A20 failure
4)Super I/O chip failure
5)Keyboard controller test failure
To Sum it up : System board failure
You can call Dell Tech Support and check for repair options:18772931197 , you can also check with Local Tech.
You can try releasing flee(static) power and check
Let me know.
Thanks.
Mar 09, 2014 | Dell XPS Computers & Internet
Engine management warning light on
Engine management warning light on ?????? What DTC'S - diagnostic trouble code's stored in the PCM - engine computer ? Should have DTC'S stored
Oct 14, 2017 | 2006 Saab 9-3 Convertible
Dave- could you please give telewest keys for 2nd march 09
key 00=aa b7 d1 d9 ce 8e 83 af
key 01=a1 38 06 29 24 29 8d 2b
Mar 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Verbatim external 640gb harddrive is unreconised.CONSTANTLY.
ok.. here's a few ideas...
Before Connecting the external drive:
first close ALL RUNNING PROGRAMS
REINSTALL DRIVERS..REBOOT
make sure no programs are running once again...
make sure your usb cable is WORKING...
NOW...
Connect.....Wait for it (a minute or two MAX)....
If this doesn't work, then I suggest using a few google searches..
Try the following/similar: Searchwords
External Hard Disc Recovery Tool (or toolkit)
*Also, Never NEVER erase any default/hidded files that came preinstalled/included on that drive....(eg...system files)...
let me know if this helped...c-tekk@hotmail.com
Nov 22, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Gearing stopped
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted alex@fixya.com (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email1.gif him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Mar 30, 2008 | Hobart D300-6036 Mixer
No video - Blinking code 5
yes im a tech unknown business i cant say what business or my name could lose my job but her you go, Fix the blinking light code 5 blinks turn down your picture vivid and your contrast ive makde plent of money fixing this issue for the company.
Feb 01, 2008 | Sony KP-53HS10 TV
Crown CE1000 2-Channel Amplifier Logo
302 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
