Question about HP DesignJet 3500cp InkJet Printer
System Error 020000
Hello all
After unfaultering service my HP Designjet 3000CP is now giving me a "System Error Code 020000" and this is accompanied by a grinding sound. I have looked on the internet, but cannot find out what the problem is.
Can anybody tell me what this means, how to fix it if possible, and if I need to call in a technician - what the cost to me may be? I live iin Jersey City, USA.
Your help would be much appreciated.
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
antiochpc
  • 1314 Answers
SOURCE: error code 070020
From the service manual:
070020
One of the Drop Detection errors has occured - or, during the Drop Detection no drop was detected.
Pen checking is set to OFF.
Corrective actions:
1. Perform the drop detect calibration
2. Troubleshoot the cartridges and the drop detector
3. If required, replace the service station
4. Check the cable assembly and the main PCA.
If you are inclined, I can upload the service manual for you which tells you how to enter the service mode and perform the drop detect calibration. Warning: If this is done incorrectly, it could render your machine useless so if you are not inclined to do so, hire a professional to do it. Otherwise let me know and I will upload the manual for you.
Posted on Feb 18, 2009
RPFinney
  • 385 Answers
SOURCE: hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Posted on Apr 17, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
HP Designjet 5000 5500 parts
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
Hp plotter designjet 1055 CM plus plotter produces system error
Jul 31, 2009 | HP Office Equipment & Supplies
Error code 79:04
System Error: 79:04
Problem Description: Firmware Error.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer on again and check if the Error Code has disappeared.
If the Error Code reappears, check for a new Firmware release.
The firmware upgrade and tool can be found here.
Jun 16, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Not printing
Do you mean your printer is connected to a usb port at back of computer? Obviously it must be or no communication would occur!!! What error messages are you getting?
Aug 08, 2007 | HP DesignJet 3000cp InkJet Printer
HP DesignJet 3500cp InkJet Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
