Question about Kenmore Dryers
My dryer will not stay running when it has clothes in it.
When the dryer does not have clothes in it then it runs fine, when you put clothes in it shuts off within a few minutes.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Your motor is bad...they are famous for it...! As soon as it has some real work to do...It fails. If it runs for a minute or two...with clothes and no unusual noise...then it clearly the motor...
Posted on Nov 04, 2008
Kenmore 90 series dryer runs fine until I put clothes in it then it shuts off after I let go of start button
If you are lucky, it is just a heater relay.
You can actually use the motor relay to test if the heater relay is bad, by switching them around. They are interchangeable!
Below is a parts layout for reference.
  1. Unplug power
  2. Then pry the left end cap loose
  3. Remove the philips screw holding the control panel
  4. Remove the back panel plate to inspect, see below diagram:
25997497-lbinchh11fp0u2viv5ufwbp2-3-2.jpg Unplug the wire harnesses of both relays and plug the heater wires into the motor, motor wires into the heater.
If the dryer stays running when you push "start", you must replace the heater relay!
Note: Do not run your dryer until you have all returned the wires to their proper relays...
Dec 07, 2015 | Kenmore Dryers
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
The gas dryer won't stay heated up.
Do you have stacked clothes on top of it or anything else? If so remove those items and never put anything on there. it's not a table it needs to be clear so heat can dissipate from cabinet. IF that doesn't solve it write bac
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
Electric clothes dryer
The most likely cause is a bad timer. The timer determines how long the unit stays running (drying the clothes). A timer is typically $100-150.
Secondly, it could be a faulty motor. This part generally cost about $100-200 dollars.
Mar 21, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
