Question about Aiwa Audio Players & Recorders
Aiwa CX-800 sound problem
I am wondering if my audio channels are blown. The graphic equalizer LED bars indicate sound, but all I get is a 'popping' like noise, regardless of band, station or CD/cassette play. Time for a new tabletop system?
  • 319 Answers
SOURCE: cassette doors
Bent or broken door latching part. Take in for service
Posted on May 07, 2008
SOURCE: technics sh-eh790 stereo system
Hi there just wondering, if you cant fix your problem would you sell your sound processor as mines broke beyond repair. My email is cocksure001@homail.co.uk.
Posted on Jan 14, 2009
SOURCE: How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
Posted on May 28, 2009
SOURCE: Aiwa CX-ZHT63 Display Trouble
I own a NSX-MT960 and the same thing happen , DEAD DISPLAY.
I just happen to be retired Certified Electornic Tech and Held a FCC first class ticket, and own a tv-vcr -stereo repair shop that worked on all brands,
I had to fix alot of items WITHOUT THE HELP of a schematic diagram and got to be pretty good at it,
THIS HAPPENED about 7 or 8 years ago, but it still may help somebody,
THE DISPLAY IS A VACUUM FLOURESCENT and has a low voltage heater circut to heat it up like old vacuum tube, AIWA PUT IN A SURGE CURRENT LIMIT RESISTOR about a 1/2-1 watt unit with LOW OHMS, I FORGET NOW BUT a 1 watt .5 ohm resistor will fix it, OR JUST JUMP IT for a short time to test, but put that thing back in, better to burn out that resistor than the heater circuit in the display.
HOPE THAT HELPS
RETIRED TELEVISION REPAIR ENGINEER THAT TROUBLE SHOT DOWN TO THE COMPONET LEVEL< NO BOARD CHANGER HERE!!
THAT WAS THEN < THIS IS NOW, NOW YOU HAVE TO CHANGE BOARDS DUE TO SMD WAVE SOLDERING , YOU WILL RUIN A PCB WITHOUT TENS OF THOUSANDS OF DOLLARS WORTH OF DESOLDERING EQUIPMENT.
BEST REGARDS
Posted on Aug 30, 2009
I have an Aiwa cx-nma545 w/o the remote. What is the model number to the remote itself? Or do you know how I can replace it?
http://m.ebay.com/itm/AIWA-RC-ZAS05-AUDIO-SYSTEM-REMOTE-CONTROL-CXNHMA86-CXNHMA86U-CXNHMT75-/331729077190
Remote is no longer available from Aiwa nor most remote resellers. Ebay is your only source. The above link is to one available currently on ebay usa
Aug 18, 2016 | Aiwa Televison & Video
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Need a manual for a Aiwa model# CX-NAJ5OU
http://www.manualslib.com/manual/3631/Aiwa-Nsx-Aj50.html?page=3
Mar 23, 2015 | Aiwa Audio Players & Recorders
Aiwa mod. CX-ZR774 System will not power up
I assume that the Aiwa controls the other components, such as a CD changer. If these units are plugged into the rear of the Aiwa, then they may not be receiving power due to an auxiliary switch being off, or a bus breaker being blown. Breakers are on the back panel of the unit. They have a black thumbscrew that turns out counterclockwise. Take the fuse to Radio Shack to confirm if it is good or not, and good a new one if not. If the components are not connected to the Aiwa, then I have the ask the stupid question of are they plugged in, or is the surge protector that they are plugged into plugged in. Remember that even modern surge protectors have breaker switches, and may need resetting, especially after a snow or thunderstorm. Good luck.
Jan 27, 2014 | Aiwa Audio Players & Recorders
Where can i get a free user guide for aiwa cx-nmt520
gm rick hoffer go to this site then type in your model number good luck....http://esupport.sony.com/
Jul 08, 2012 | Aiwa Audio Players & Recorders
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
In car graphic equalizer installation
035132ed-916f-4d02-8e5e-9fa428212a36.jpgPyramid stereo graphic equalizer model 9700g - Page 6
Mar 23, 2009 | Pyramid 801 10-Band Car Equalizer
AIWA
Aiwa is owned by Sony few years back.
You can download Instruction Manual of Aiwa NSX-A888 (CX-NA888) from Sony Support.
Regards,
Sep 26, 2008 | Digital Audio Electronics - Others
I have a aiwa cx-na77, how do I connect it to a tv so that I hear the tv sound on the aiwa speakers
If it has an "AUX" input or any other type of RCA jacks for an input, you can connect the TV RCA audio jacks output to the input RCA jacks of the Aiwa.
That's what you would need.
RCA audio outputs on the TV
RCA audio input on the Aiwa
Just look at the back of each unit and see if it has them. RCA audio jacks are the small circular red and white jacks. They will be labed on each unit what they are for. You need output jacks on the TV and input jacks (but not for phono) on the Aiwa.
Aug 08, 2008 | Aiwa Audio Players & Recorders
218 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
