Question about RCA 27V530T 27" TV
Show for one minute then tick tick and shuts off
This problem occurred after i installed a new flyback. When i turned up the volume ,the TV went tick tick' and then it shuts off. I turned it back on and same thing. What could be the problem? Thanks in advance for any suggestions that might be relevant.
    Problem Solver:
  • 6 Answers
Check Regulator for 132V +-. Check for 32kv at CRT anode. Try lowering screen control on the flyback.
Posted on Nov 04, 2008
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Sylvania TV - 3 tics
Not economically. The ticking sound is a sure sign of high-voltage shutdown, and is coming from your flyback transformer - the most expensive part in the TV besides the picture tube. Even if it's not the flyback, troubleshooting the high voltage section is usually more than the cost of a new TV.
Dec 30, 2008 | Sylvania 6427TE 27" TV
Shows for one minute then goes tick, tick and shuts off
ok try this , unplug the front control board , if it stays on then thats the problem , but if it don't , then you will need to check the components around the EEPROM and resolder all components that heat up, it is possible that the crystal and EEPROM may need to be replaced but doing these other things plus a couple of more checks will help find the culprit
also make sure all work is good, resolder and recheck are the best way to eliminate any problems
please give a fixya rating so that i may continue to help you if needed , thanks
electech
Nov 03, 2008 | RCA 27V530T 27" TV
My TV
the old ticking sound... yes.. it means your power supply shut down and continously trys to reboot ... hense the tick sound as the voltage rises and fails.
Means you got a short somewhere. Most likely the obvious high power consuming High Voltage Suppy... and as I found in 99.9 percent the Horizontal power Transistor shorted... 80 percent Flyback, 10 percent audio... 10 percent some odd circuits like vertical or yoke as shorted.
you have a short.
Sep 10, 2008 | Sanyo DS24424 24" TV
Panny tv problem
yes i did its on the original post, in this cae i dont think it is the flyback with the extra detail you have just given.. Read the main post for more details
Jul 14, 2008 | Panasonic PT-51HX40 51" Rear Projection...
TV making ticking sound when turned on
most times I hear that ticking its the high voltage failure ...most likely a shorted HOT fallowed by flyback. the ticking is your shut-down engaged.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Samsung TXM3296HF problem - tv won't turn on
your flyback transformer could be your problem or in the video circuit.have a tech look at your tv for possible repairs.good luck.
Apr 01, 2007 | Samsung TXM3296HF 32" TV
RCA 27V530T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
