Question about Fujitsu 18C1 Air Conditioner
Replace remote control unit model ar-fb2
I have a Air condition Fujitsu model ASU 18T unit outdoor, but my remote control model ar-fb2 is not working. I need replace it cause rignt now I can turned off the AC.
Please send any solution.
Sara
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
caroldon
  • 17129 Answers
SOURCE: Dear expert, Our dog chewed up
Get your Dog to the nearest VET immediately. The next thing is to ask your Fijitsu dealer for a spare remote control.
If not then you must check out if the multipurpose remtoe will work out with this model.
Get help from an accessories shop to give a remote to test/replace before buying.
Posted on Sep 11, 2010
  • 382 Answers
SOURCE: i am looking for a
dear sir
please use blow link and further information about fujistu air conditioner in near of your area dealer for find out your aircon remote:
http://www.fujitsugeneral.com.au/find-dealer/dealer-search.php
thank you
hope answer the question
please vote!
Posted on Oct 01, 2010
hvac1960
  • 2133 Answers
SOURCE: We bought a house with
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Posted on Dec 09, 2010
My remote control is not working i have fujitsu air condition model #AR-RY6 can i use different model ?
There are some other Fujitsu models that will work but not all. The remote controls from Fujitsu themselves are not too expensive if you want a genuine one. Call them for a replacement or try a cheap universal remote from somewhere like ebay or Aliexpress.
Oct 15, 2016 | Fujitsu Heating & Cooling
My remote control is working i need replacement is for fujitsu air condition model #AR-RY6 or can i use different model
I find that most remotes from the same manufacture work on different models. Fujitsu is big enough where I think its worth a try.
How do i sync a fujitsu ar-dl2 air conditioning remote with air conditioning unit
Here is a link to current units: http://www.fujitsugeneral.com/PDF_06/OperationManual/(OM)ASU24CL-30CLX-36CLX.pdf
there is no indication that synching is required for OEM remotes, just chack and make sure the batteries are good. If it is a universal type remote, the remote manufacturer provides those instructions.
Nov 26, 2014 | Fujitsu Heating & Cooling
Dear expert, Our dog chewed up our "remote control unit model: AR-DB4". We live in Curacao, so my question is, where can we order another remote control for our Fujitsu air conditioning? ... It's...
Sep 11, 2010 | Fujitsu 22U Air Conditioner
Fujitsu air conditioning remote control not working (model AR-NJ1) . Tried different batteries with no result. Thanks!
open the remote and carefully look at where the batteries make contact they sometimes bend in and dont make contact just pry them out a little and reinsert batteries and it often will work again
Jul 07, 2009 | Heating & Cooling
Jan 15, 2009 | Heating & Cooling
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Dec 01, 2007 | Heating & Cooling
Fujitsu 18C1 Air Conditioner Logo
503 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
