Question about Hitachi 43UWX10B 43" Rear Projection Television
Flashin power light - wont come on
I hear a chirping noise and the front power light flashes in sequence to it when turning on the TV, and TV will not work. When peaking behind TV through holes in the back, one green light (on circuit board) stays green and another flashes to the chirping, too. this occurs at 1 second intervals.
    Genius:
  • 1,694 Answers
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Posted on Oct 18, 2007
  • Vista Electronics Oct 19, 2007
    Thank You for the good rating! If I can help further,let me know!..T.
2 Suggested Answers
SOURCE: chirping noise and flashing front power light.
hey techman - when you say shorted do you mean shorted in the IC or where the ic solders to the board?
Posted on Sep 26, 2006
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Blue light flashes on front of tv cannot get set to turn on
my sanyo 37 inch was workin fine put it on the wall now the blue light on the front is flashin like mad screen wont *** on got the clicky sound as if i was turnin it over by the side any ideas ??
Aug 21, 2010 | Sanyo 42 in. LCD TV
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
Dec 29, 2008 | Televison & Video
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
TV wont come on
some electronic components inside your TV had shorted out! you might be hearing a slight CHIRPING! like the sound of crickets! or maybe whining! the sound migth be coming from the transformer/inductor with a shorted component on its output!
Nov 16, 2007 | RCA F32650 32" TV
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
Jan 29, 2007 | Philips 32PW6506 32" TV
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43UWX10B 43" Rear Projection Television Logo
643 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
