Question about HP Officejet 7310 All-In-One Printer
Scans & copies have vertical line through them. I am not using the ADF. I have cleaned the glass & looked at the glass and it does not appear to be scratched. The vertical line is consistent and occurs in scans as well as black and white copies. It's a Model 7310. After some remote troubleshooting, HP is recommending that I just buy a new one instead of getting this one fixed.
After troubleshooting with HP for about 90 minutes and discussing my lack of enthusiasm at their proposed solution, I purchased a new all-in-on printer.
Posted on Nov 05, 2008
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
A vertical black line appear on each paper when the document feeder is used to make copies; such vertical line does not appear on papers when copying on the glass surface. How do I resolve this...?
when you open the copier platen cover, left of the copy glass, there is small narrow glass, which is used when you make copies from ADF. Over that glass is plastic protective sheet. Remove it and clean, also clean the glass. Use glass detergent and after cleaning dry it!
Even the smallest dirt can cause lines!
Hope that helps!
Apr 25, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
On my Canon Pixma MP780 a vertical line appears on copies made using ADF
I tried the other solutions listed here - and no luck. After cleaning the inside of the ADF, like the manual suggested - no change. How are you supposed to do that anyway? Deep cleaning the inside of the machine also has nothing to do with it.
I finally figured out why things that I copied with the ADF had lines/marks on them, but those placed directly on the platen (big glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Nov 27, 2007 | Canon PIXMA MP780 All-In-One InkJet...
160 people viewed this question
Seeker5211
Seeker5211
