Question about IBM Infoprint 1120 Laser Printer
IBM INFOPRINT 1120 Invalid Engine COde
All four engines are selected at 0*, still getting invalid engine code. Does anyone know what this should be?
  • printfly Jan 09, 2009
    my display printer tipes " invalid engine code " HELPPPPP
  • 26 Answers
Invalid engine code --- is a bad engine board - located on the LHS of the printer behind the formatter board
Posted on Apr 16, 2009
Need print driver for ibm 1120 using win 7 64 bit
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
Dec 12, 2012 | IBM Infoprint 1120 Laser Printer
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
Invalid engine code- how do I fix this
First try this link:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:179:0:0&mode=DOCS&doctype=KB&term=invalid%20engine%20code&docid=BPD10
And if you do need to update the engine code, you can download it from this link. It also has instructions on how to update the code if your device is locally attached (via a USB cable).
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:179:0:0&mode=DOCS&doctype=KB&term=code&docid=ENUS9414
If the device is on the network, download the engine file from the above link and follow instructions to update the code using the link below.
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:179:0:0&mode=DOCS&doctype=KB&term=code&docid=BPD35
Hope this helps.
Jun 01, 2009 | Lexmark Optra T612 Laser Printer
Invalid engine code
The easiest way to solve this is to work through Lexmark Technical Support.
Their web site may have the correct engine code on their site, but installation of the code can be tricky.
Are you getting a 900 Invalid Engine code message?
Don
Apr 23, 2009 | Lexmark Optra T614 Laser Printer
Lexmark T522 (invalid Machine code)
i take it that your getting an invalide engine code error? this is caused usually by the printer taking a power surge. you can get a batch file from lexmark to reflash the engine board however if it will take the code it usually odesnt last to long. change the engine board and your problem will go away
Mar 17, 2009 | Lexmark T522 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Invalid Engine Code After Paper Jam
remove the driver of the printer and reinstall...
Apr 01, 2008 | IBM Infoprint 1125 Laser Printer
Invalid engine code
Hi, Are you getting any numeric messages in this error?
Dec 04, 2007 | IBM Infoprint 1120 Laser Printer
Invalid Engine Code
This is actually a Lexmark printer, so what I'm quoting is a Lexmark sol.
turn off machine
hold down returnand go buttons
turn on printer
hold  until performing test shows and let go of buttons
it will go to a service mode ( instead of saying ready)
got to printer set up
hit select button
go to engine 1,2 or 3
try each one ( hit select to go into that perticular number)
what you are looking for is a number that has an * next to it. Use the arrow keys to scroll. most likely it changed the setting so go and look for that number w/the * and hit select when you see it.
Sep 26, 2007 | IBM Infoprint 1120 Laser Printer
Have to replace controller board / engine board
controller board and engine board are on the left hand side of the printer. remove side cover (plastic) and screws to silver cover. controller bd is first - just a bunch of screws and one in the back where the eithernet plug area. (some you dont have to remove but mostly remove the big ones - it will come free. Keep track of which screws go where. The engine board is next. All the plugs are either size or color coded you cant mix them up. a few more screws and the engine bd is out. Reverse to install.
Sep 25, 2007 | IBM Infoprint 1120 Laser Printer
IBM Infoprint 1120 Laser Printer Logo
496 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
