Question about Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo
Blown fuse on panasonic tv
TV would not turn on when power button is pushed. Removed back cover and noticed a blown fuse, replaced fuse, but when I tried to plug tv into outlet, fuse blew again, repeated this process twice. Each time fuse blew. Any suggestions? Looking for help, before taking to a repair shop. Thanks. Bruce
  • 1 more comment
  • Anonymous Nov 26, 2008
    t.v will not turn on
  • vigbound Jan 01, 2009
    Tv won't come on. Red flashing light where on button is
  • Anonymous Feb 20, 2009
    My Panasonic wouldn't turn on either. Replaced fuse. three days later. blown. replaced fuse. two days later, blown again.
    service is expensive to come out $100 for estimate.
    Panasonic has no idea to help nor will help - out of warrenty.
    any ideas how to fix?
    Genius:
  • Panasonic Master
  • 1,550 Answers
Maybe the horizontal output IC are on short circuit.
Posted on Nov 04, 2008
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
How do you replace a fuse on the 2011 Panasonic TC-P55VT30 plasma TV?
gently lie it facedown and unscrew the back to reveal the boards and fuses
Jul 28, 2015 | Panasonic TCP55VT30 55" VIERA 3D HD Plasma...
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SIMPLY DID NOT MAKE A SOUND WHEN THE POWER BUTTON WAS PUSHED
The main a/c fuse is likely blown -6.3A 250VAC- Replace with a 7A 250VAC.
To replace - remove back cover - once removed follow a/c cord to TV and fuse is on the board close by. google "GMA fuse" images to see what fuse looks like -the one without leads -clip in type.
Oct 24, 2009 | Panasonic CT-32SL14 32" TV
TV WONT TURN ON
Got it fixed. Removed back off tv and found the fuse right where the cord enters. Removed fuse[didn't look like it was blown] and got new one from radio shack, installed and now the tv works. That was all it was. Thanks again
Apr 05, 2009 | Panasonic CT-32SL14 32" TV
Panasonic HDTV /no power
the loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Nov 25, 2008 | Panasonic CT-36HL43 36" TV
TV does not power on. No Stand by light either.
Your power supply is shorted out. Get a good repairman to fix it..."exspensive" repair if you screw it up.
Apr 30, 2008 | Insignia IS-LCDTV32 32 in. Television
TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Jan 09, 2007 | RCA F36665 36" TV
Open Questions:
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Logo
805 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
