Question about Whirlpool LGR7646E Dryer
DRYER BLOWING COLD AIR-NOT HEATING UP
WHIRLPOOL LGR7646EQWW BLOWING COOL AIR / NOT HEATING UP,
  • 6 more comments
  • al4-link Jan 13, 2009
    I have somewhat of the same problem. Have a Whirlpool Gas Dryer Model LGR3624JQ2. When it first starts there seems to be heat then quits. You can open the door and there is heat in the drum. Start it back up and it is cold. Seems to be intermittent with the heat. Vent is clear and gas is on. Thanks for the help. Al
  • thongy May 05, 2009
    hi i have condencer dryer its a creda , it is just blowing out cold air and does not seem to be getting hot any ideas what it could be please thanks jayne
  • Anonymous Mar 12, 2014
    my hoover hd dryer only blows cold air
  • Anonymous Mar 24, 2014
    I have a Siemens dryer and it stopped blowing out hot heat it only blows cold air. What could be causing this?
  • Anonymous Mar 26, 2014
    whirlpool
    My whirlpool gas dryer is blowing cold air.
  • Anonymous Mar 30, 2014
    blowing cold air
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
I hope this helps....
Posted on Jan 21, 2009
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
We have a Kenmroe dryer model 970-c85192-00 that only blows cold air right now.
Check the heating element and the thermal fuses for continuity first
Dec 29, 2012 | Dryers
I have a duet electric dryer. It isn't getting hot air
This video shows how to get into the machine. Your heater slides out and is easy to replace by removing the bottom panel. Looks like this:
Jul 30, 2010 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
Dryer run but dosen't heat strong cool air flow from rear of machine
heating element needs to be replaced, its just blowing cold air and probably the vent hose is loose
Sep 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
Apr 10, 2009 | Whirlpool GEQ9800L Electric Dryer
My dryer is just blowing cold air
Check the breaker box make and make sure the breaker is all the way over to the on side and then if it still continues check the thermal fuse and the heating element.
Apr 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Mar 04, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Dryers Logo
5,000 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
