Question about iRiver H340 MP3 Player
Can't charge I can't charge my MP3, either with the mains cord or battery pack. This makes me think there is something wrong with the socket on the unit. Any ideas how to fix it or get it repaired? I live in the UK. Many thanks
  • Anonymous Nov 20, 2007
    I received the MP3 player as a gift. I charged it as directed for three hours. It worked for one day. The battery will not recharge. Please help.
  • Anonymous Feb 02, 2008
    When i plug my ipod to the charger i can leave it on here for like 4 to five hours and once i unplug it for about five minutes it works then it dies please help.
There is a smill switch on bottom, you need a paper clip switch it off and on a few times.
Posted on Nov 27, 2007
Does your power adapter flash while plugged in? If so what has happened is the connector to the battery has come undone. Simply remove the screw on the bottom (under a stick-on cover), slide the case off, unscrew the 4 small hard drive mounting screws, and plug the battery back in! Easy! Caio!
Posted on Feb 01, 2007
Make sure mp3 is switched on to re-charge. Some MP3's will not recharge while switched off
Posted on Jan 31, 2007
    Problem Solver:
  • 10 Answers
Try ukipodrepairs.co.uk we are the largest and longest running iPod repair comapny in the UK, it sounds like it needs a new logic board.
Posted on Oct 09, 2006
I am Alex Harvey. I have this mp3 player that does NOT charge and it charged last on Monday Sept.5.2006 and I have not had for long. So whoever that reads this and has questions please call me at home at 250-573-3597 or e-mail me with your phone number at alexharvey1239@hotmail.com And I live in Barnhartvale Kamloops Brittish Columbia[BC]. Thanks alot guys Alex Harvey
Posted on Oct 06, 2006
  • 175 Answers
Check the battery voltage make sure its original. If not rejuvenate it.
Problems with iPod Mini
Headphone sockets on these after a while can become loose at the solder joint on to the board, they develop cracks in the joint making a poor contact, dismantle and resoldering headphone socket terminal is the fix.
As for battery life, it sounds like the battery pack itself is stuffed, there is now fix except to replace battery pack, recharbel nicad batterys do wear out. You could also check that termals on battery and ipod are clean and making a sound secure connection.
Nov 16, 2007 | Apple iPod mini M9160LL/A MP3 Player
When I connect the dc plug into the laptop the laptop shutsdown
I have had a similar problem. If the battery is not holding a charge, then something is wrong with the charging circuit inside the battery pack. Remove the battery pack from the computer and reconnect the power supply and see if it stays on. If not you will need to check the voltage for the power supply.
Mar 05, 2015 | Lenovo G505 59371430 AMD E1-2100 1.0GHz...
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB...
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB cord to charge the battery on the screen appears the following: IDLE and some kind of symbol. Can you please help?
Dec 16, 2010 | Truly MP310 MP3 Player
Difficulty charging
Sounds like you have a bad internal dc jack. These go bad after so long. This is a normal problem on all laptops. Make sure it isn't your battery by seeing if you could use another same model battery. If having tried a new charger and a battery and the problem still persists then take it to your neighborhood computer shop or send it to me. I can replace the dc jack for you since you'd have to sodder a new one on.
Mar 18, 2010 | Acer Aspire 5570-2067 Notebook
RCA MP3 M208 won't hold charge -- Only about a yr old
either the battery pack itself is bad, or the ribbon connection cable that attaches battery to main circuit board is faulty, broken, or loose. It is common.
Nov 11, 2009 | RCA M4208 MP3 Player
JVC Camcorder - used wrong power lead to charge battery
They sell external battery chargers for these for around 10 bucks at Amazon. Just pop the battery in the charger. Beware the battery itself can be worn down or dead. It also has protection circuits right inside the battery that can be blown (maybe a small fuse too). A new high capacity battery (3 times the recording time) is also at Amazon for around $25.
Mar 31, 2017 | JVC Everio GZ-MG130 Camcorder
Batteries not holding charge
they have a battery tester software online free 15 days or so that would tell u maby did u buy generic power pack also
Jan 11, 2008 | Dell Inspiron E1505 Notebook
Charging ipod
Have you tried connecting your ipod with a different cord? Or maybe a different charger? Also, try to plug it directly into the socket--not a power strip or something like that.
This is an interesting problem.
Nov 08, 2007 | Apple iPod MA446LL/A MP3 Player
Phillips hdd120 will not charge
i think battery is disconected inside unit, or battery is very dead. open up unit and look / test battery for life. or replacebattery
May 05, 2007 | Philips HDD120 MP3 Player
iRiver H340 MP3 Player Logo
244 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
