Question about Funai Televison & Video
Reset the clock - Funai Televison & Video
Go to setup find clock with remote set date and time
Posted on Dec 14, 2008
How do I reset the time on my HHScott Inc Atomic Clock ?
An atomic clock should set or reset automatically. That's what an atomic clock does. Right now my clock reads 1:35 and the computer read 1:37. Go figure : - )
Nov 21, 2016 | Home
The atomic clock did not reset to daylight savings time. How di I reset it?
Depending on which country you are in (the UK won't reset for a couple of weeks yet), your clock will automatically reset when it receives the adjusted time signal. If your clock is not receiving the signal, try moving it near a window and away from any electrical interference, or it is possible that your battery is getting low and has not got enough power to receive the signal.
Mar 08, 2015 | SkyScan 86709 Atomic Wall Clock
How to reset wesrminister wall chime clock
If this is a mechanical clock, make sure the chime lever is set on. If quartz there is a reset button to forward the chime advance until it matches the hands.
Mar 19, 2013 | Seiko Mantel Clock
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Toyota Yaris 2009 Clock Reset
Check your owner's manual. Then try the other button? This is a new car, though. Try disconnecting the negative battery terminal for about 15-minutes to reset 'all'.
Nov 11, 2009 | 2007 Toyota Yaris
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
Outside temperture
After changing the batteries on the outside unit, remove the batteries from the clock for a few minutes, then replace them. This will reset the clock to 'talk' to the transmitter.
Nov 21, 2007 | SkyScan 86709 Atomic Wall Clock
Televison & Video Logo
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
