Question about JVC HR-A592U S-VHS VCR
Can't see menu to programme VCR
Up until this afternoon this function worked just fine. About 10 minutes later, when I pushed the menu button so I could programme some shows in for recording tonight, instead of getting the blue screen with the menu list, all I got was a black screen with nothing on it. I tried pushing other buttons, turning the VCR and TV on and off, but nothing brought the blue screen with the menu back. I read the instructions and nothing explained how to correct the problem. All other functions still work fine. Any suggestions. The VCR is just over a year old. Thanks. Donna
    Sergeant:
  • 337 Answers
Try unpluging the unit from the wall for about 5 minutes then plug back in and turn it on,this will reset the brain and go back to normal.
Posted on Oct 05, 2006
My Jazzy 600 was plugged in & charging and I did not know this. I tried moving the scooter & it would not work. I tried on/off & fast slow until I finally found the plug in was the reason. Now...
I think I understand what you are describing based on some inadvertent button pushing on your part.
Sleep mode programming on the VSI controller by Penny and Giles Drive technology is the idle time of the power chair before it "goes to sleep". This computer menu is accessed using a hand held PP1 programmer that is plugged into the charging port of the joystick. Using this programmer one can scroll down to the sleep mode menu and set the time from I think 1 to 120 minutes ( I have not accessed this particular programming menu for quite some time).
If I put in 10 and save this number the chair will go into sleep mode after sitting and not being used for 10 minutes. The control may have dropped one of the settings due to a program glitch. I do not know of a way to reprogram this by pushing buttons on the control itself.
You should drive the chair into a local dealer who has a PP1 programmer and let them program it for you. This is a 2 minute deal and they should do this as a courtesy for you at no charge. If a technician comes out to your house they may charge you a minimum 1 hour labor charge.
While they have the programmer plugged in, have them check the fault log for any other problem areas. Hope this helps.
Feb 26, 2011 | Pride New Jazzy 600 Power Wheelchair by...
Can only use programmes which allow changing the crust setting to 'dark' other programmes half bake the bread.
This is a tough one. One thing you might try until you can replace your machine is to look in your manual and look at the page that shows the cycles of the program you chose. I wonder if you could shut the machine down after the last rise cycle next time,,,,,the,,,,. Push the Stop button until it beeps.... then unplug your machine and reprogram your breadmaker on the "Bake" program and set the time by pushing the timer advance button in 10 minute increments to the equivalent of the last bake cycle of your original program for light crust bread? That just might work!
Oct 22, 2010 | Panasonic Kitchen Appliances - Others
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
Oct 18, 2010 | Kenneth Cole Watches
After turning on tv 5 to 10 minites later a black
this is closed caqption go into menu and turn it off or if remote has cc button turn it off with that.
Aug 11, 2009 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
JVC HR-A592U S-VHS VCR Logo
174 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
