Question about Pioneer VSX-D509S Receiver
Powering off my stereo goes on for 3 seconds and then says "powering off" and goes off
I have this same problem.  I'm not sure what output stks are.  Can you please help with this.
Eric
Posted on Nov 22, 2008
    Sergeant:
    Champion:
  • 227 Answers
Hello, i think that your output stks are gone, replace them
Posted on Nov 04, 2008
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
I have a Harman Kardon HK-3375 stereo receiver. I
A power switch either works or does not work. It does not power on and then mysteriously power off like yours is doing.
You have some sort of power relay that is being powered off after a few seconds.
I would check out the power supply for your anomaly. And no, it is not a simple fix like you are capable of performing.
Apr 01, 2017 | Harman Kardon HK 3375 Receiver
My new Clarion CMD6 stereo won't stay powered up.
If all power and ground are good to go then the unit needs to be fixed. Being that it is more likely to "see" moisture, it may have water shorting out the circuits.
Jul 03, 2009 | Car Audio & Video
Error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
May 31, 2009 | Panasonic Audio Players & Recorders
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
Power issues
It sounds like you are drawing to many amps and you need to go to a higher capacity altinator and a second battery would be a good idea as well. Start your car (do it at night makes it easier to tell) turn on your headlights without your stereo on look at head lights and see how bright they are then slowly turn stereo on and up if headlights dim you are drawing to many amps and need a higher capacity alt to charge and stop you from blowing them, and second battery with and isolator so you don't draw amps from the battery that starts your car.
Jul 23, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Kenwood KDC -X969 Won't power up
Try pressing the reset button when it slides halfway open. It's a little hidden on the main button panel at the bottom. You'll need a pencil or something to press it. This usually happens to me when it's too cold and I have the panel angle set to full down tilt on my 879.
Mar 16, 2008 | Car Audio & Video
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Apr 15, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Pioneer VSX-D509S Receiver Logo
405 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
