Projection TV IS FOGGY
Phillips 53 inch
I assume you are talking about a rear projection TV, and this would be an older set. In any event, between the CRTs and the lenses, there are chambers which hold coolant. This tend to get murky after a while and need to be changed out. There is a lot of disassemby, cleaning, and reassembly involved; so, I recommend hiring a proffessional. Also, if you live in a dusty environment, you might first want to try cleaning the top of the lenses and the projection mirror. Be careful with the mirror - they are very thin and easily broken.
Posted on Nov 09, 2008
My sony projection tv is foggy and misty
It sounds like your lenses, mirror and screen needs cleaned from the inside. I have a tip at http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv which wll explain the process and walk you through it.
Thanks for using FixYa and for the generous rating.
hardrocko
Sep 21, 2010 | Sony KP-53V90 53" Rear Projection...
I have a dptv305f phillips tv and the color is almost foggy and it seems like the colors are really green or red
Very common problem caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit at www.tvrepairworld.com which also comes with instructions.
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
Jan 14, 2010 | Sony KP-53V90 53" Rear Projection...
Foggy picture
not worth it, likely been dropped and all the lenses etc are out, or just worn out from a hard life.
Oct 12, 2009 | Philips 9P5034C 50" Rear Projection...
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 50V500 rear projection tv.
Clean the lenses. This involves taking off the screen, which often involves removing every front panel on the set from the bottom up. Have somewhere to rest your screen, like an ottoman.
http://www.keohi.com/keohihdtv/learnabout/generaltips/screenoptics/cleaningtheoptics.html
Apr 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Zenith pv5263bt 53
If this is a projection TV, first you should check you lamp. Is it good (clear) or bad (foggy). If foggy, you should replace it. If it is good (clear) reseat it back onto the ballast (it just might be loose). If you are still having this problem, you probably need to replace the ballast
Mar 25, 2008 | Televison & Video
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
