Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint FEW 12
I have a hotpoint FEW 12 which begins the wash cycle normally, but when the drum starts to rotate, it cuts out and jumps to the red light ( programme end) any ideas ?? - thanks, - alex.
Hi there i have had this problem before and found out it was due to to much weight in washing machine? or maybe your drumbelt may be loose which is connected to drum at the back on the inside? hope this helps
Posted on Jan 17, 2009
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
I have a hotpoint aquarius WF32O and when i put
is it spinning and craccleking,,carbons faulty in motor ;;will work on spin but not lower voltage wash?
change carbons,, use genuines,only
Jun 21, 2010 | Washing Machines
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint FEW 12 filling problem
possibly overfilling, or blockge in dispenser or hose from dispenser to drum.
Oct 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WD420 1200 Spin
Hi I have an Indesit WE16 with some of those symptoms and cannot figure it out - so please don't rate this as useless yet! I am beginning to suspect a bad connection to the motor and I have noticed that the drum only turns anticlockwise in my case - if the program calls for clockwise rotation the machine just hums for a few seconds and then stops.
Does this apply to your machine?
Please add a comment and maybe together we can sort both of them out. D
Jul 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
367 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
