Receiver won't turn on
Disconnect all the speaker wires, then turn the unit on. If it does not power on and the standby light is "out" pop the top and check the internal fuse by the power cord. Beyond that, without the proper testing equipment, it's all a guess. If the unit turns back on with all the wires disconnected, then reconnect your speaker wires one by one and test each time. If it does not cut out, you found the problem. Wire touching. If it cuts out, disconnect wire at the speaker and re test, if it still cuts out, replace the wire and try again. Then re connect the same speaker to the new wire and test. If your lucky, all will be well. If not, it will need to be serviced or replaced, based on cost. Hope this helps
where is the fuse for str-de310 sony receiver
Mine hasn't been working for two days now. Any thoughts on if its a fuse issue?
