Question about Dell 962 Photo All-In-One InkJet Printer
Carrier stall. Have dell photo aio 962. how do i fix a carrier stall. Thank you. Bob Hindmarsh
  • Anonymous Nov 19, 2008
    I had a similar problem with my 962. First a loud clunk is heard as the print heads hit the right side of the printer and then the "carrier stall" message is displayed. I found that the print cartridge carrier could not traverse the left half of the printer. The small white clip holding the ribbon cable where it feeds into the inner part of the printer had popped out slightly and the cartridge caddy was being stopped midway. After snapping back in, the cartridge caddy could move all the way across. I powered up and it worked OK.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
Trying to add dell photo AIO 962 printer to my toshiba satellite laptop which is running windows 7. have followed dell website instructions to download driver/firmwear etc and chosen vista 32bit under drop...
Hi! Regarding this matter. The dell photo AIO 962 may not be compatible with windows 7 thats why it gives you the error message. You downloaded the driver using vista32 but you have a windows 7 on you machine, its not gonna work. It may work on the toshiba if you gonna downgrade from windows 7 to vista, but if you dont want that option you can wait for sometime to have an AIO 962 update for windows 7 for it to work. Hope this helps and have a good one!
May 12, 2010 | Office Equipment & Supplies
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
AIO 962 How to change ink cartridge
If the printer is off, turn it on. If the printer is busy, pause or stop the job. Open the printer by lifting the scanner bed. The print cartridge carrier automatically moves to the center of the cartridge bay. Note that the Photo All-in-One Printer 962 can hold the scanner bed in the upright position without a prop. Press down on the tabs to open the cartridge carriers.Remove the old ink cartridges.
Dec 30, 2009 | Dell Office Equipment & Supplies
I have a similiar problem with my Dell AIO Printer 962
reinstall the printer and fax cd that came with your computer
Jul 10, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 carrier stall. Have tried the solutions suggested by damanpreet_c but it is still whacking the left hand side of the casing.
Look at the plastic strip with the fine lines that the cartridge goes along. Make sure it's clean. Use a damp clean cloth.
Feb 19, 2009 | Dell 962 Photo All-In-One InkJet Printer
Can't find Disc 2
Dell.com, click the support tab. Model>Printers>Printers>962>Confirm.
There are all drivers that you need. Any other untilities can probably be found on the site as well.
Apr 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Error 2200
Error 2200 is a Scan Carrier Stall error... Maybe the scan carrier stalled during a scan job. Turn off the printer, wait a few seconds, and then turn on the printer.
Jan 29, 2008 | Dell 962 Photo All-In-One InkJet Printer
My Dell AIO 962 Printer does not respond
The printer is dead and needs replacement. If covered under warranty, u can get a replacement from Dell. Speak to Dell support and they can give you alternative solution.
Nov 08, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
197 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
