Question about Dryers
Awz 865 condensing dryer not collecting water
  • kim2911 Mar 09, 2009
    i have the same problem
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Need more info to help you
Posted on Nov 04, 2008
We have a awz 865 dryer element & thermostat working yet clothes not drying what could the problem be
How can the heating element be working if the clothes don't dry?
Feb 28, 2017 | Dryers
Whirpool dryer awz 865
If you had line voltage to ground you'd trip the circuit breaker, without a schematic cannot pinpoint it exactly but all dryer gas or electric have a high limit thermostat which opens if the exhaust is plugged up stream, remove the exhaust tube connected to dryer and see if it heats correctly if it does the exhaust leading out of the house is plugged also the operating thermostat you referred to has a set resistance reading at room temp this tells and changes based on heat this is what controls voltage to the heater would need a full model number to give more specifics.
Jan 15, 2014 | Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
I got a Whirlpool AW Z 865 dryer. It is a condenser dryer and the water is not going up to the collecting bucket, but remains below and then leaks out and floods the floor when I open the little pull door...
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
Nov 25, 2010 | Whirlpool Dryers
Whirlpool AWZ 8577 Tumble Dryer The water is not collecting in the top water container
You have a water pump in the base of the appliance this can sometimes fail or block. On the back of the dryer there should be a pipe just pull that off and blow down it, if there is a block this may well remove it. If not it's likely a pump failure.
Hope this helps
Mar 20, 2010 | Whirlpool Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
396 people viewed this question
Top Dryers Experts
