Question about Panasonic SC-AK110 CD Shelf System
Cd's skipping many cd's, new and old, have started skipping,eratically. the same cd's play fine on my computer. what do i do, aside from throwing the cd player out?
    President:
  • 3,130 Answers
Try first to clean the lens with a lens cleaner disc. or cleaning the lens manually. if that does not help, then im afraid the unit has come to the end of its usefull life. and is time to get a new one . Good Luck
Posted on Oct 05, 2006
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
Dec 13, 2009 | Technics SL-PD6 5-Disc CD Changer
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Skipping yamaha 765
I have a very similar type unit, a Nakamichi CDC-3 that had the same problem. I found this link....
http://repairfaq.ece.drexel.edu/REPAIR/F_cdfaq6.html#CDFAQ_001
I spent about two hours fixing mine. The sled mechanism was binding somehow, causing random skipping. The first 10 minutes was getting it apart and figuring what was wrong, the remainder was spent getting all those tiny parts back in the proper place.
Look up the exact symptom before going at it (probably long skips). Set aside a long slow lazy day with nothing to do. DO NOT drink too much coffee, you will be handling tiny parts that go in tedious locations, so you don't need caffeine jitters adding to your misery. Take your time and be careful. It's well worth it. Mine plays like a new one.
Nov 26, 2007 | Yamaha CDC-585 5-Disc CD Changer
Cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Nov 25, 2007 | RCA RS2653 Shelf System
E250--several problems lol
it could be either a bad usb hub or cord for the sandisk e250, but it would most likely be that one of your CD's is either corupted, or your sandisk detects a virus and is skipping through the song.
Jan 08, 2007 | SanDisk Sansa e250 MP3 Player
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
Noise, gurgling and stopping CDnwhile driving
GREAT SOUND BUT THE CD MECHS ARE (HOW SHALL I PUT IT) THROW IT AWAY
IT NEEDSA A NEW CD MECH
COMMON PROBLEM
Oct 29, 2006 | Nakamichi CD-500 CD Player
Panasonic SC-AK110 CD Shelf System Logo
121 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
