Keep getting the following message when trying to send an email - "send test e-mail message" failed. Can receive them but not send. Have checked smtp server address and port etc. and all seems fine.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Depending on the software you're using and network configuration, there are several answers. The first thing I would try is checking the SSL settings VS the settings provided by your email provider.
Posted on Nov 06, 2008
Can recieve but cant send
Unable to Send Email? Check These 5 Things - rackAID
https://www.rackaid.com/.../cannot-send-email-how-to-fix-email-sending...
This likely means SMTP authentication is not enabled. If you get a relay denied error and your password is correct, then SMTP authentications is likely not correct. Often, email users with this issue can receive but cannot send email.
I am receiving email fine, but I cannot send messages ...
www.gn.apc.org/.../i-am-rec...
Association for Progressive CommunicationsThe usual symptom is that Thunderbird will try to send for about 20 seconds before giving up with "Sending of message failed. The message could not be sent ...
Are you able to receive emails but not send? - Hostgator.com
support.hostgator.com > ... > Email > Email Troubleshooting
If you aren't able to send email, this usually means one thing: your internet provider is blocking you from using anyone's outgoing mail servers but their own. ... so that theycan monitor outgoing email on their network in order to prevent spam.
Problems Sending Mail - Receiving is Fine - InMotion Hosting
www.inmotionhosting.com > ... > Email > Email Troubleshooting
Jan 14, 2015 - Outlook 2013, cannot send mail, but can receive mail ... I haven'treceive any mail since yesterday and I can't send mails too... can you help me ...
I can receive emails but i can't send them. ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple
Jan 20, 2016 | Le Pan II 9.7" Tablet PC
Tip
How do I Send a PDF file to my iPod
<p>If you have documents stored in Adobe Portable Document Format, or PDF files on your computer that you want to share with someone, send an email to the receiver, which then retrieve the email application on your computer. If your receiver an iPod Touch, a portable media device from Apple, they can access the Internet via Wi-Fi After they released the iPod Touch Mail app native and check the last to receive e-mail, the PDF file appears as a attachment to what she read on the device. <br /> <p><br /> <p>1. Launch your email application on your computer. <br /> <p><br /> <p>2. Start a new email message. Enter the email address of the recipient in "To" field or click the recipient's address in your contact list automatically add to the message box "To" field. <br /> <p><br /> <p>3. Click "Confirm" or "File" menu of the application of e-mail, click "Confirm" and click a folder on your computer you want to send the PDF. PDF Click to select it and click Open. Your e-mail you can also drag a PDF file from a folder on the hard drive of your computer directly into the box e-mail to confirm. <br /> <p><br /> <p>4. Click "Send" to e-mail with attached PDF file. Your recipient can then check your e-mail from your iPod Touch, tap the message you, and then tap the PDF document to open and read. <br />
on Aug 05, 2011 | Apple iPod touch
I keep getting "content has expired" message when
You need to delete browsing history or reset your browser..
Mar 22, 2011 | Yahoo Mail
Getting error code for sending e mails from Windows Vista home. Ox8OOCCCOD
Third Party Solution Found: From Microsoft
Error 0x800CCC0D
Problem: When you try to send or receive email, you get an error message. It
says the error number is 0x800ccc0D.
Solution: This error is basically saying that your computer cannot connect
to the mail server. The most common and obvious cause of this is that you
are not connected to the internet at all. To test whether this is the case,
try opening a news web page like news.com or doing a Google search (just
opening your homepage is not a good enough test, because it may be saved, or
"cached", on your computer's hard drive). If this test fails, then the
problem is not with e-mail specifically, but rather with the internet
connection. For users on dial-up, you need to dial in first, and then you
should be able to check your email. If Windows is indicating that you are
already connected, try disconnecting and then dial in again. If that fails,
try restarting the computer and then connecting again. If that fails, you
may have spyware or your modem may have gone bad.
If, on the other hand, you are able to pull up web pages, yet still get
error 0x800CCC0D, you should check to make sure the mail servers are typed
in correctly. To check this in Outlook Express, open the Tools menu, select
Accounts, click on the Mail tab, click on the Properties button, then click
on the Servers tab. Or, if you use a different email program, follow the
equivalent procedure for that program. The incoming mail server should be
pop3.vcn.com unless your email address doesn't end with @vcn.com, in which
case put in whatever your address ends with instead of vcn.com (for example,
if your address is person@wavecom.net, enter in pop3.wavecom.net ). The
outgoing mail server should be smtp.vcn.com or substitute whatever your
email address ends with for vcn.com.
Make sure to check the mail servers for all your mail accounts if you have
multiple email addresses.
If you still get error 0x800CCC0D, and definitely can pull up web pages
(that is, the rest of the internet is working fine, only email is having a
problem):
* Restart your computer. This is simple, so you might as well try.
* Try disabling e-mail scanning in your anti-virus program. To do this
in Norton, double-click on the yellow picture for Norton down at the bottom
of your screen by your clock to open Norton. Then click the Options button
at the top of the window (if a drop-down menu appears, choose anti-virus),
then click the word Email on the menu on the left side. Uncheck both Scan
Incoming and Scan Outgoing. Click OK, then close Norton. Try checking your
messages again.
* Disable your firewall. It could be blocking Outlook Express, or
whatever your email program is, from accessing the internet. McAfee firewall
will usually not turn off even when you tell it to, so you'll have to go
into the firewall settings and delete your e-mail program from the blocked
list, or just uninstall McAfee firewall entirely using the Add/Remove
Programs control panel.
* Make sure you recieve replies when you ping the mail server. If you
cannot, something strange is going on.
* Try checking email using a different mail program such as Thunderbird,
or through webmail on our web site, and see if that works.
Other Cases
You may be able to get mail when you first open Outlook Express, but then
get error 0x800CCC0D from then on. To solve this, go to the Tools Menu >
Options > Connection tab, and uncheck "Hang up after sending and receiving".
Your email works fine, but error 0x800CCC0D keeps constantly popping up over
and over. In Microsoft Outlook, Tools > Options > Mail Setup tab > Send and
Receive, and uncheck "Schedule an automatic send/receive every 5 minutes"
(older versions of Outlook will have a similar option under the Mail
Delivery tab). In Outlook Express, go to Tools > Options, and uncheck "check
for messages every ... minutes".
Shenan Stanley
MS-MVP
Quoted and pasted by Jack Isaacs for FixYa
Hope This Helps.
Jack Isaacs
Jan 29, 2010 | Microsoft Windows XP Home Edition
Easycap 4ch usb DVR no email sending
when i use multiviewer and set up mail, it tests ok but will not send an email.
i think it has limitations, the first email i setup had secure login required, and that didn't work, so setup another that wasn't a secure login server. and that tested fine.
but still trying yp get it to work.
Ritchie
Dec 28, 2009 | Home Security
Cannot get or send mail. error ox8oocccod
Error 0x800CCC0D
problem):
messages again.
Other Cases
Aug 30, 2009 | Sony VAIO JS Series Desktop Computer...
How to Set up Juno Email in Microsoft Outlook2007
Tools > Account settings > E mail accounts > Change > More settings > Outgoing server > Check the box which says > My outgoing server says authentication . Finish
Apr 21, 2009 | Microsoft Office Outlook 2007: Windows
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
