Question about Kitchen Ranges
MY CANNON CAMBERLEY DOUBLE OVEN HAS HAD A REPLACEMENT FSD BUT IS STILL NOT WORKING PROPERLY.
  • NdeStX Mar 02, 2009
    Mine is the same...hobs fine, top oven fine although it doesnt' stop clicking when i use it, main oven - no gas.
MY CANNON CAMBERLEY main oven is not working at all. No Gas, no ignition, hobs are okay, clock is blank.
Posted on Nov 19, 2008
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
Cannon camberley double oven the lower oven will not work and no gas is coming through to it but the top oven works fine can u help. Thanks Steve
Just got one today and have the same problem. Have read on here you need to set the clock to turn on the gas. Now i just need to figure how to set the clock.....
Nov 25, 2009 | Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
My g70m oven ignites and stays lit but it won't heat up it stays the same all the time
Hi
You have one of these faults:
Faulty FSD (Flame Safeguard Device). When you turn your oven on the FSD lets a small amount of gas through, after about 30-90 seconds the FSD is satisfied and allows more gas to come through......this then moves over to the.......
Oven Thermostat, this will sense the heat from the oven and adjust the temperature accordingly.
If the flame doesn't go high after 60 seconds it's the FSD, if it does but then it goes low and fails to increase then it's the Thermostat.
Either way you need to get a qualified gas engineer to look at it.
I hope this helps
Steve :)
Apr 05, 2009 | New World G70m Gas Double Oven
You need to press the cook period button. You'll see a counter that says 0.00. Press the + (or - button if you have gone too far) to set the time you want the oven to stay on for. When the timer runs out, it will beep with the alarm, and at the same time cut off the gas supply to the oven.
Annoying, but a good safety feature. I normally put 3 hours on to make sure it stays on for the full length I am cooking for.
How do I get my grill working???? Its how I found your question. The dial won't even turn in that direction, and I am sure there is a similar safety device in place. Might be the same one. Will try (just typing helps me think).
Nov 19, 2008 | Kitchen Ranges
Cannon Camberley 10305G (Double Oven)
trust you have set the clock as this turns the gas supply on to the ovens
Dec 19, 2007 | GE Profile JGS968 Gas Kitchen Range
Oven heat
The problem with you oven is the FFD (flame faliure device ) also known as FSD (flame safety device) The way is works is that when an oven is ignited first time the heat from the low level flame heats phail at the end of the calliary tube which in turn increases the pressure within this tube forcing open the FSD valve to open allowing full gas through. when this fails it restricts the amount of gas flowing through it leaving the oven with a small flame. these are easily repalaced but the law says it must be done by a corgi registered engineer for gas safetey reasons...But 110 % that is your fault. HTH
Dec 04, 2007 | Frigidaire FGF316 Gas Kitchen Range
Cannon chichester calor gas oven
The FFD or it might be called an FSD in cannons case is faulty it needs replacing. The fault is that it is not forcing open the valve to let teh gas come through when it gets hot... These are easy to fit if you know what your doing .... Be careful it is a corgi man job. Flame faliure device or flame saftey device.... 100 %
Nov 20, 2007 | Cannon 10476G Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
536 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
