Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Left not transfering cold enough air to right side. doesn't get colder than 50 degrees, why?
Left side ices up on back wall. right side can't chill lower than 50 degrees. Check'd flap on upper right side- working fine. Help!!
Freezer not freezing temp 20 degree
Posted on Dec 13, 2008
  • 1,543 Answers
Remove back panel of freezer (where you see the frost) and melt the frost with a hair blower. The frost blocked evaporator coils are not allowing air to pass over the cold coils, so no cold air is able to get to the fresh foods section. You will most likely need to replace the defrost heater at the bottom of the evap coils to prevent this from reoccurring in two weeks time.
Posted on Nov 04, 2008
Hi..our maytag msd2351HE side by side is only making small amounts of ice..we are able to get water..Any suggestions?
I would suggest pulling the refrig out and removing the lower panel . On the right , there is a black box ( condensor ) . The fan pulls air thru the coils and dust , lint , etc , can block the air flow , causing the freezer to not get cold enough ( 5 degrees ) for the ice maker to work . Also check to make sure the fan there is working . If the fan is working and the coils are clean , try turning the freezer control slightly colder . If the fan is not working , replace the fan motor .
Aug 01, 2010 | Maytag MSD2351HE Side by Side Refrigerator
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
The refrigerator on my side by side doesn't appear to be cooling as cold as it used to be. It's maintaining about 50 degrees. I've turned the knob up to the coldest level, but it doesn't get any colder...
Check the evaporator fan inside the freezer compartment. You should hear it running if you open the door while the compressor is running. It blows cold air from the freeer into the fridge. If the fan is running, there could be a problem with the damper which regulates airflow into the fridge.
Jun 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge is not cold enough and the freeze is colder and has ice
hi. thanks for the question. the drain tube that goes down to the drain tray is clogged. turn fridge off .pull fridge from wall. remove back panel clean all coils. let it thaw with doors open, it will thaw quiker. when thawed, clean the drain tube. this will solve the problem. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Installed replacement Icemaker but will not dump new ice...
Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
232 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
