Question about Hyundai ImageQuest Q17 17" LCD Monitor
Monitors goes black - Hyundai Q17
Hello, My monitor (Hyundai Imagequest Q17, 2 years old) remains black after I turn it on. The green power light is showing. And if I look very closely at the monitor, I can see whatever is on the screen, but all is dark. Could it be possible that it is the bulb which died ? What over possibility have I ? Thanks for the help Nicolas CJ
  • 2 more comments
  • Anonymous Aug 14, 2008
    I have to same problem...i am looking for blacklight model #...please help
  • ranakpur Sep 28, 2008
    My Monitor has a Similar Problem. But it is like this.... There is no Display, The Green LED is ON. when i switch off and put the Power button on the LCD ON, it shows the complete display for just a fraction of Second, then again it goes off. How much warranty does a Hyundai ImageQuest Q17 LCD Monitor has over it.???
  • nmoor Oct 28, 2008
    my screen is blinking to view just when i turn on through 1sec.but the led is green
  • ritzru4me Jan 14, 2009
    I have the same exact problem!!! What do I do?????? Please help
I can verify after opening my monitor up as well that the solution posted by W_Steenhuis does in fact work. The power cord itself didn't have an adapter, but the power "adapter" was in the base of the monitor itself. The big circuit on that was where I found a diode and resister side by side that were badly burnt. I basically put some solder down each of the connections to the board to broaden the overall connection of each just to make sure that there were no gaps. Now my monitor works :)
Thanks again, W_Steenhuis.
Posted on Nov 07, 2008
I had the same problem some time ago.
After dismateling the power-supply unit it apeared that there was en crack in a solderjoint at one of the power transistors. This transistor has 3 legs (TO220 I believe), from which the middle leg had a solder crack, probebly due to thermal stress. Just resolder and it worked again....
Its worth a try I think.
Succes,  Wim Steenhuis.
Posted on Oct 29, 2007
Thanks. I sent the monitor to Hyundai as it was under guarantee. After a 3-months-wait (!!) it came back with a new bulb.
Thanks !
Posted on Oct 31, 2007
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
Sep 21, 2013 | Hyundai ImageQuest Q17 17" LCD Monitor
My hyundai imagequest l70n lcd monitor started to started to make a high pitched noise and the screen went black but the green light stayed on but now i plug it in and nothing happens no picture and no...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Power on Green Light Blinks but no picture. Will not turn on. Hyundai Image Quest L705
bwpvemail, The units "switch-mode-power-supply" may be in shutdown mode. A tech will need to evaluate. Check to see if Hyundai has a refurbished swapout+cash program?? It's that or trade in for new wide screen, so the tech in the store "back-room" can possibly put $8 in new filter capacitors in your unit and with a little luck will have a 17" L70s for 1-2 more years use. 12fixlouie
Dec 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Hyundai b90a monitor screen is blank... the power light goes briefly green, then goes to yellow standby... even when rebooted.
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $45 plus shipping. If your problem is not the capacitors then it would be the backlights and that is much more difficult to replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 07, 2009 | Hyundai ImageQuest B90A 19" LCD Monitor
Monitor comes on for a few seconds then off. Turn it off then back on and does the same thing.
try your colour reduce it a bit and it should work if there is to much colour it will turn on and off
Jul 02, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
Hyundai imagequest Q17 montior problem
ontherhodes5, Your monitor will probably need servicing for one or both power supplys in the unit. Yes, If you can get a new oem Switch-mode-power-supply/inverter board you might get it working. I suspect that it (smps) can't supply the voltages needed by the logic-interface board- therefore no digital data can be processed for display on the screen, which should be white-bright but now only gray. (dim) because the 1000v ac from inverter circuit is also missing 10to40% of it's output. Your best bet will be to find out if Hundai can do a repair/swapout. You send yours+$40 to $90 and they send you a Refurbished same model with new CCF tubes, Inverter board, smps board. It seems that sooner or later these lcd ccf (cold cathode fluorescent tube backlights) will need servicing. Don't feel bad about this monitor. There are about, (guess only) 2500 more of all makes and models with similar power supply problems out there. To see whats inside a lcd search YOUTUBE for vids of servicing or repair of lcd screens or similar.. also www badcaps.net ??? or lcdrepair.us or visit electronicrepairguide.com run by a Jestine Yong. Ignore the sales pitch and just look fyi. hope this was of some help. drop me a note if possible. I'm louie12fix on fixya or lmistyrel@ aol.com BYE
Mar 29, 2009 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Speaker in screen dosen't work
a normal minijack (3,5 mm) cable, with the same plug in both ends.
if you have a cable already, try to adjust the volume using the buttons on the screen
Mar 10, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
Screen does not start (switch on)
Sounds like a mode issue. Make sure you have the pc set to a compatible mode for the monitor. You may also want to double check the vga cable is firmly set in the monitor and pc.
Aug 22, 2008 | Hyundai ImageQuest Q17 17" LCD Monitor
Automatically turns off and on withing 2 secs
the power button board is electronically fried you need a new one
May 07, 2008 | Hyundai ImageQuest L50S 15" LCD Monitor
Open Questions:
Hyundai ImageQuest Q17 17" LCD Monitor Logo
759 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
 steve
steve
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
