Question about RCA HDLP50W151 50" Rear Projection HDTV
Rca hdlp50w151 screen removal
I need to remove the front screen to get some dust out. I have removed the rear screws and the front grill but can only tilt the screen forward a few inches. Is there another screw or press fitting at the bottom? I dont want to force and break something. There were 2 screws at the bottom of the screen with the grill removed but they didnt help when removed. Thanks for any info...
  • Anonymous Jun 05, 2008
    how do i remove the screen to clean inside
  • Anonymous Dec 01, 2008
    need to clean out the spider webs ?? go figure, but don't want to break anything.
Remove the 3 screws about 3 inches in on the back side of the speaker cover on each side. pull out and slightly upward on the speaker cover to remove. supsupport the cover if you do not want to disconnect the ground and button control cables. Remove the screws on the top and side rear panel to front frame/screen cover. tilt the screen cover out about 12 in at the top and lift up. Reverse the procedure to reinstall.
Posted on Aug 13, 2012
  • Matt Moreno Oct 11, 2015
    Just to add some more detail here; You have to remove the back cover first. Then behind the back cover on each side there is additional screws that are not visable with the back cover still attached. Remove those hidden screws then the front speaker grill will pull off. Be gentle with it, tilt it back a little then pull out. It has friction style fasteners on it, similar to a car door panel that hold it on.
I have a projection tv Mod# P60925BL Chassi# PTK195LC
I have a convergence problem and bowing
convergence board no longer available
Is the board repairable? What parts fail on the board?
any suggestions appreaciated / Thanks
E-Mail Address / Rayo2@cox.net 01/04/2k8
Posted on Jan 04, 2008
    President:
  • 3,130 Answers
Almost every set comes apart a differant way. My advice would be to go ahead and get the service manual if you want to do this type of service yourself as then you will know for sure if your taking apart the proper se quence of parts in the order they should be. As I remember a lady customer once , started to take apart her projection set, and did not not ewhat to take apart and it ended up costing herover a grand as she took out some critical screws that made the main mirror inside the set to drop and break and caused damage to two of the main projection lenes!!! My advice to you here is get tyhe service manual as I wish i had it to give you but I do not. If you invest like I think 20 to 30 bucks and go to http://www.servicemanuels.net you can be sure of what your doing and how to do it for your set! Please report back and tell us how myou made out?!
Posted on Oct 05, 2006
How do i take off the front panel assembly on my rca hd52w59
The lower front speaker grille will need to be removed first by removing the screws along the back edge of the rear cover as shown in the pic below. then just pop the lower speaker grille off then you will see the screws along the bottom edge of the front control panel and also on the rear edge again then that panel lifts off but you will need to reach behind as your removing it to unplug the wires that are hooked to both small circuit boards on that panel ( keyboard & aux input boards)1_28_2012_3_47_13_pm.jpg
Jan 27, 2012 | RCA HD52W59 HDTV Projection Television
Kp57ws500 i need to remove the front screen for transport. the back panel is off. how do i remove the front screen panel?
You need to take the front grill off. There are two screws on the front at the very bottom. They are covered by a little plastic insert for cosmetics. Remove the screws and gently pull the bottom grill down. You will see wire connectors you can disconnect to completely remove the grill. After that, there is about 5 screws under the screen bezel that are holding it in place.
Feb 05, 2011 | Sony KP-57WS500 57" Rear Projection...
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
Dust buildup behind the screen
Remove speaker girll.No screws to remove grill just pull off.At the bottom of the screen frame you will see 4 1/4 inch screws.Remove screws and lift screen straight up.Clean cob webs and clean off lenses.I do not reccomend cleaning the mylar mirror.It is very delicate and you will scratch it.You can use windex to clean lenses.Good luck.
Jan 19, 2009 | RCA P52926 52" Rear Projection Television
How do i remove the front screen to clean the mirror on the inside
usually you need to remove the speaker grille then you will notice a few screws in the lower screen frame remove thos screws then grab the screen frame and slide up wards to disengage the clips that hold the screen assembly on.
May 16, 2008 | Hitachi 61SDX01B 61" Rear Projection...
RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Apr 13, 2008 | RCA P52937 52" Rear Projection Television
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Jan 21, 2008 | Televison & Video
52" rca model #p52930bl
The plastic screen itself never gets dirty on the inside, unless a spider has taken up residence nearby. What you are likely experiencing is dust built up on the CRT lens and mirror - which would cause the picture to look dull with low contrast and brightness. If that is the case, you may find on your model that the screen either pulls out or that there is a wood piece at the bottom that is hiding some screws or maybe the speaker grill needs to be removed to expose said screws. Be gentle cleaning the mirror, as it is surface coated and could be scratched easily.
Dec 26, 2007 | RCA D52W19 52" Rear Projection Television
Inside screen seems to be getting dirty
I had the same problem until I removed the screen and cleaned the front mirror with a static feather duster. First, turn OFF power. Second, remove screws on rear at top and on both sides of the screen. Third, remove speaker grill. Fourth, remove screws on each side of the screen where screen meets the speaker area. Fifth, remove two screws in center area of speaker area under screen. Sixth, lift screen up and away from set housing and use a duster with a two to three extension and GENTLY wipe the noticeable dust layer from the front tilted mirror located behind the screen at bottom of screen. Seventh, do everything in the REVERSE and you're done. If you need to replace the lamp, now's a good time to do so. Also you should clean the dust filter located behind an access door on the rear (right hand side as your are looking at the rear) with a handheld type of vacuum device.
After I completed ALL of the above procedures my WD-62525 was better than I remember. I bought it in 2005 and the picture quality has never looked so good.
The screen is as light as a feather but 62" is awkward. It is recommended you use another person to hold the screen but I work best alone and it was a breeze.
GOOD LUCK.
Dec 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Help
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you. to remove the screens remove the front grill, then remove the screws @! the bottom of the screen & if i remember right the top just sits on a lip, so gently try to lift the screen up.careful, these screens are expensive & you will have 2 or 3 of them. some of them are really easy to scratch.
Oct 22, 2006 | RCA P46924 46" Rear Projection Television
RCA HDLP50W151 50" Rear Projection HDTV Logo
380 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
