2600C1 Pace box inactive for 2 months. When switched on red light is on in power on/off button and is permanently on no matter what I do, it wont even switch off.  There is no control over anything and when I use the remote not a glimmer of life. I have tried another remote but no difference.
  • 1 more comment
  • jewson Nov 04, 2008
    The box is "locked"in the standby state (red light) No sign of activity, the "remote"indicator light does not come on when using remote. Cannot switch off manually, red light stays on no matter.
    What else can I say, the box is in standby (red light on) and wont come out of it remotely or manually, all very frustrating
    I have solved the problem of the red light staying on. I threw the box under a road roller and bingo the light went out.
    Many thanks for all your input I will keep trying. (I was only joking about the roller) Any further solutions will be welcome. Fred T.
    Brigadier General:
  • 6,966 Answers
Initially, sounds like a failed firmware on your Satellite box. However, pls try:
  • disconnect the power;
  • press and hold BACKUP button on the front panel;
  • reconnect the power while still pressing on the BACKUP button;
  • wait for all four front panel lights to light up;
  • allow the unit to reload software.
Alternately and if you are somewhere in Europe (UK?), pls reference this page.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 04, 2008
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Genius:
  • 1,913 Answers
Reset it press power button for 10 seconds
I had the same problem with my Sony projection tv . I called a tv repair man from yellow pages and he replaced two chips on the motherboard for $150 and the tv works ever since !!!
  • 899 Answers
Have you tried unplugging it for a bit , and see if it will come out of that state?
if it does not then there is an electronic component problem in the standby circuit or a power issue in the circuitry , which then it will need testing to find the culprit
electech
    Genius:
  • 2,920 Answers
It sounds as though your power supply may be dead
    Brigadier General:
  • 3,614 Answers
Ut better to check the switch, its possible that it was stuck or faulty. or try to change the remote battery as well.
  • micromaster
    micromaster Nov 04, 2008
    its possible that it was stuck or faulty switch. due to some moisture or dust
Headlights wont turn off
check fuse box for corrosion. Have definitely heard of corroded fuse boxes shorting and allowing power to continue through the circuits
Feb 07, 2014 | 1990-1993 MERCEDES BENZ 300SL 300 SL...
I have bought an Antsig universal remote control for my Sony DVD CMT-GP8D but the 4 diget code is not in the operation book. Please help
Have you tried the manual option? Turn on your DVD player. Press "TV" or maybe a different button for DVD players, then a red light on your remote blinks once. Then hold both the "up" volume and "up" channel button down until your red light is permanently on. Then whilst holding your remote control 1mm away from your DVD player signal light (usually red too), hold down the "power" button until your dvd player switches off. Then switch it on again and try other buttons. However, I've only tried this on an LG TV, but took me 2 days until I really put the remote in front of that signal light. Took about 1 minute or more while holding down the "power" button. Hope it works =)
Jan 30, 2011 | One For All URC4110 Remote Control
Arc mouse wont turn on, it was working fine until it started to get unresponsive and the red light started flashing so i replaced the batteries but now it wont turn on. I even tried connecting the reciever...
In extensive use the USB-device overheats. Removing it when not in use helps, but it is allready permanently damaged and only real solution is to switch the mouse to new one.
Guarantee is 3 years. Wich is a good thing because these tend to fail in 6 months to 2 years.
May 27, 2010 | Microsoft ARC Mouse
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Sumsung Omnia Screen Inactive
Try going into the Menu.... Then "Settings" icon. Click the "System" tab on the bottom, then go to the "Power" icon.. Then click on the "Battery Power" tab for options.
My settings are as follows.....
Turn off device if not used for 5 minutes.
(Checked box) Turn off back-light if not used for 30 seconds
(Checked box) Turn off back-light when a button is pressed or the screen is tapped.
I don't seem to have a problem getting my screen back up after being inactive. If your settings are ok, and you still have the problem, I would have it checked out. Maybe a defect?
Hope this helps....
Feb 03, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Dell Dimension 8200 won't power up
If the power button does not light up at all, I would guess the power supply has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
Sep 21, 2008 | Electrical Supplies
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
