Question about U-Line Icemaker
Uline ice maker not cool enough to make/keep ice
Our Uline ice maker no longer gets cool enough to make/keep ice.
  • Anonymous Mar 20, 2014
    wiggle it and it will turn and dump ice melts at some point when arm is stuck but then freezes back
    Problem Solver:
  • 10 Answers
One of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Posted on Dec 19, 2008
HELLO I HAVE A ULINE WH95TP IN A BOAT WE HAVE IN FOR REPAIR AND THE ICEMAKER WONT GET COLD WAS WORKING BEFORE ANY THOUGHTS ON WHAT TO CHECK THERE ARE NO SCHAMADICS ON IT THANKS JOHN
Ice makers need refrigerant just like freezers and if it get too low it will quit working and probably burn itself out .call a refrigeration repair person and ask them to check it out .
Jul 30, 2015 | ULINE U Line Marine/rv Ice Makers Wh95tp...
Ice maker keeps making ice, does not stop when bin is full
the ice maker should have what is called a bail arm that is what measures the ice in bin if there is one it should only move up and down if it moves any other direction the bail arm post could be broken
Oct 30, 2012 | U-Line Uline Origins Series...
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
My Uline icemaker model WH95 TP will not make ice. It is cold enough to store ice. Installed on boat. What parts should i replace and is there a diagram for a DIY.
Your ice maker may be out. You CAN do this yourself. Do you clean it twice a year with nickel safe im cleaner? That's a great way to keep it in good working order. We have parts if you would like to contact us. Should you get your parts from us, we will provide instructions for you. Hope this helps!
Aug 18, 2009 | U-Line Icemaker
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Jun 01, 2009 | U-Line Uline Origins Series...
Water runs, but no ice being made.
check if the fan near the condenser is still running.
check also the lever if it is in the down position. if it is in the up position, that means you turn off the ice maker.
check if there is frost on the freezer, if it is cooling very well.
keep me posted,
drcool
Oct 14, 2008 | U-Line Icemaker
Problem with cooling and fan on frige
no fan then no cooling!
try to localise the problem by removing the fan and powering it up direct from mains. if it works then problem is not with fan
Jun 25, 2008 | Refrigerators
Uline ice maker
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email OnlineService@U-Line.com for help
http://www.U-Lineservice.com
May 13, 2008 | U-Line Icemaker
U-Line Icemaker Logo
589 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
