Chgr err on panasonic scpt760 - Audio Players & Recorders
  • Anonymous Mar 05, 2009
    chgr err on panasonic scpt-760
What i am supposed to do if i get chgr erro on panasonic scpt 760 receiver
Posted on Dec 08, 2008
Model SA-PT960 says chgr err
Can be a fault on the mother board as the fault seems to be linked to two issues. The failure of the loading drive and also a failure in the system control.
Unless the unit is opened up and checked the exact fault cannot be confirmed. Sometimes itt can be a jammed drive, faulty motor or drive or a dirty optical lens.
Nov 12, 2011 | Panasonic Televison & Video
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
May 09, 2011 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I only use it for surround sound but I cannot use it for...
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Jul 05, 2010 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-AK640 mini stereo system and I'm receiving an error message ''CHGR ERR''. The disc tray will not eject. I've tried to power the stereo off and on several different times. What else...
The CD loading mechanism is out of time and has not reset correctly. This cannot be reset. The loading mechanism must be dis-asembled and rebuilt. This is not a DYI repair. Any Panasonic service center can repair this for you.
Dan
Jul 06, 2010 | Panasonic Audio Players & Recorders
I have an SC-PT760 that the only thing that works is the stereo.The on/off button on main unit doesnt work. Keeps saying ''chgr err'' and makes clicking sound. I just found out it was discontinued. I see...
I wish I had a solution for you. Mine just did the same thing (it's only a year old). I called into Panasonic, and they very briskly told me all they could do was give me the number of a local repair man. I called them, and was told it would cost about $250 to fix it.
Dec 12, 2009 | Panasonic Audio Players & Recorders
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
Chgr err message on display. what does this
IT MEAMS THE MECHANISM IS MISSALIGNED.NEED TO SEND IT IN FOR ALLIGNMENT
Jul 25, 2009 | Panasonic Audio Players & Recorders
I have a err code "chgr err" on my panasonic sc-pt960.
This would indicate a CD/DVD Changer Error.
The system thinks there is a stuck disc or other wierd problem with the CD/DVD changer.
Unfortunately these issues are rather hard to fix, due to the way the changers work.
Opening these units isn't that hard, however fixing an issue with the changer is very difficult and is best left for a specialist.
You may need to contact a local Panasonic repairer to get this one fixed.
Use the link below (if you are in the US) and enter your model number and ZIP code to locate your nearest repairer.
http://www2.panasonic.com/consumer-electronics/support/?cm_sp=Homepage%20Support-_-Header%20Support-_-Support%20For%20Customers%20Link
Best of luck, and sorry that I could not be of much more help than this.
Jun 22, 2009 | Panasonic SC-PT960 Theater System with...
Sc-pt760 "chgr err"
For panasonic sc-pt760, if the DVD player is busted, you can't access the option to switch to Digital in. With Digital in, you can still use the unit as a sound system by feeding it through the optical input from your TV.
but, the trick, You can't access the switch menu without an ipod. For some reason, you can switch from an Ipod to your D-in. You can't switch out of AM/FM to d-in as it tries to access the broken DVD first.
Jul 02, 2008 | Panasonic Home Theater System System
352 people viewed this question
 Grubhead
Grubhead
