Question about Epson Stylus Photo 950 InkJet Printer
Paper twists when feeding
Just after the paper begins to feed, it twists, as though it is feeding faster on the right side than the left. I have run some Epson cleaning sheets through and they now feed ok, but regular paper still twists.
It also now turns up, or folds the front left edge of the paper. if it manages to feed a sheet of paper through.
    Problem Solver:
  • 28 Answers
There is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
Posted on Nov 18, 2008
Paper Shooting Out
Please have a Check on the below mentioned Points and follow the steps:
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Good Luck!!!!!!
Mar 28, 2013 | Lexmark X4650 All-In-One InkJet Printer
Tip
My X2250 will not feed the single sheet of paper evenly. When looking at the...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 28, 2008 | HP PSC 1610 All-In-One InkJet Printer
As the paper starts to feed through, it jams on the left side, as if the left side roller is feeding the paper in faster than the right side
Take a soft cloth (not paper towel) moistened with alcohol and clean off the rollers that pickup the paper. Make sure you clean the entire roller. Chances are that there is paper dust on one or more rollers and they're slipping, causing the jam.
Feb 26, 2011 | HP Photosmart 2610 All-In-One InkJet...
It appears that the paper is not feeding on one side. The paper will begin to feed and then turn crooked.
First make sure that the left hand paper guide is up tight against the stack of paper in the feed tray.
If it is and the paper is still skewing then something is obstructing the path. This could be an internal part that has come loose, a piece of torn paper or a foreign object like a paperclip or wasp. Use a torch and peer down the feed chute and then look inside , examine the paper path carefully.
For info, the paper only feeds from the right side (as you look at the front of the printer)
Dec 08, 2009 | Canon PIXMA MP470 All-in-One Printer
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
My printer is feeding more than one page at a time my printer is cannon 3000
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
May 23, 2009 | Office Equipment & Supplies
Paper feed problem
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Sep 11, 2008 | HP DeskJet 6540 InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Open Questions:
See all Epson Stylus Photo 950 InkJet Printer Questions
Epson Stylus Photo 950 InkJet Printer Logo
559 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
