I have two pipes for water supply (hot and cold). However my washing machine has only one connection at the back. The model is Bosch classix. Do i need another connection at the back of my washing machine?
  • 135 Answers
No this machine is cold water feed only.
Posted on Nov 05, 2008
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Just bought a new washer (refurbished, therefore doesn't come with a handbook). our old washer had both the cold and hot pipe connected, our new one (a bosch 1400 classixx) only has a white valve. do we...
You just need to collect the cold pipe- the washer does the heating itself for hot washes. It uses the water cold for rinses ;-0)
And for a manual-
you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
I have a classixx 1200 machine and there is just one fill on the back. I have just moved and am confused as the pipe is red. I fixed it to the hot water supply but water is too hot. Should it actually be...
If there is just the one water inlet connection on the rear of the washer, then you must connect it to the cold suplly, as it is designed to work of cold fill only.
Please rate my solution to your question.
Feb 01, 2010 | Bosch Classixx WVF 2402 Front Load...
for the instruction manual... you can "googe" search online for it...type your brand name in the search window with "support" and you'll most likely find the factory website with manual downloads.
For the water issue: most washers are designed to connect to a hot and cold water supply. If yours is a one water pipe connection, and you're ok with cold water washes, I'd recommend supplying water to both the hot and cold connections of the washer, so you don't have any mishaps by hitting the wrong wash cycle and not getting any water. You could purchase a simple hose bib splitter fo accomplish this.
If however, you want hot water, sounds like a plumbing job to bring hot water to the washer's location.
It won't hurt the machine to run cold water to both just won't get the hot water cleaning benefit.
Jun 29, 2009 | Whirlpool Washing Machines
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
