Question about Delphi SKYFi SA10000 XM Radio Receiver
Won't turn on
I've had my delphi sky fi for about a year and a half. All of the sudden, it won't turn on. At all. I called tech support at delphi and they told me i was screwed and had to buy a new radio. Power is coming out of my car, so the problem must be with the radio. I did not receive paper instructions with the box. Does anyone know why the radio may not be working? Is there a way to reset it?
  • czeppieri Nov 11, 2008
    Just won't turn on one day. No power. Nothing. What gives?
SOURCE: Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Posted on May 08, 2008
Benimur
  • 6966 Answers
SOURCE: Xpress RC Not turning on
Initially, pls try:
  • removing all the power connectors to simulate a reset and unit will revert to factory defaults. Let the connectors off for an hour or so. Thereafter, pls try again.
  • press on the power button when reconnecting the power connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 24, 2008
sTatiC00000L
  • 8 Answers
SOURCE: XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Posted on Sep 08, 2008
  • 336 Answers
SOURCE: My Delphi Roady XT just stopped working. The only
Its probably time to just replace it. They are not worth repairing. If you contact XM customer service they may offer you one at a discount. They replaced one of mine for $20. I thought that was a fair deal.
Posted on Nov 21, 2009
SOURCE: delphi myfi xm2go
The power adapter is the problem.
I have two of these units.
The one I was using died and will no longer power on.
So, I called xm and switched to my back-up.
That one's dead, too.
I tried two adapters, four batteries and neither radio works.
BUT, I just happened to try a third adapter I had.
After re-setting the device (Take out battery, depress reset button with a pin. It's in the upper left in back. It's a VERY small hole.)
Then, I plugged the cord back in, and the battery is charging.
Apparently, the power adapters have a limited life span.
I'll be picking up a few new ones now.
Posted on Jan 14, 2010
I bought a 2009 Hundia sonata (nice car) from Green Light auto stores.was told could re-fi in a year. I went to re-fi and was told its milage was to high .The car is worth half of what iam paying now,
All this depends on your agreement that you agreed to when you purchased the vehicle. Read the small print and if you are not sure at the time, ask. Most agreements have a mileage clause.
Mar 23, 2014 | Computers & Internet
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
Feb 09, 2013 | Televison & Video
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
Changes channels, mutes itself,turns itself off, etc.
Somewhere on the net sombody said they called tech support and was told to get a new 5V plug adapter (they are made by Belkin and available online). After suffering for a week with a loco XM radio, I got the new adapter and it worked like a charm!!! Its the thing that plugs into the wall.
Jun 06, 2010 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
My delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
Tv won,t turn on
1-877-778-8876
Call for a service call
Jul 09, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Trying to update firmward on Delphi SKYFi3.
when it gets stuck scanning. Press (volume up) and the (mode) button both down for a few seconds. when you release the two buttons this will turn it off and back on in few seconds.
Mar 20, 2008 | Delphi SKYFi3 XM Radio Receiver
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Delphi Roady XT won't turn on
Same here, it's nice to know I'm not the only one with this issue at least; but as to a way of solving this, I've found nothing.
Dec 07, 2007 | Delphi Roady XT XM Radio Receiver
Delphi SKYFi SA10000 XM Radio Receiver Logo
79 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
