Question about Microsoft Xbox 360 Console
E 73
Power button flashing red on bottom right corner Power block light is green
  • Anonymous Nov 24, 2008
    I have the same problem, but I don't use the ethernet slot on my xbox I use wireless internet.
  • BakersDozen2 Feb 19, 2009
    When I turn on my xbox, one red light appears in the bottom-right hand corner and the words E 73 appear at the bottom of my TV screen. What do I do?
DO I NEED TO SEND MY CONSOLE IN FOR REPAIR.THANKS
Posted on Nov 24, 2008
One red light flashing
Posted on Nov 05, 2008
  • 4 Answers
General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
Good Luck
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
Clear
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
My two wii remotes wont power up ,the charger is blue but when you press the power button on the remote all 4 lights at the bottom of the remote flash. what is the problem please?
You need to sync them again. To do this you must first press a little red button located in the front of the wii next to the sd card slots. Hold down for about 2 to 3 seconds. Right after wards look on the back of the wii remoter and take of battery cover. Press the tiny red button on the bottom left hand corner to sync to the wii.
Dec 31, 2010 | Nintendo Wii Console
Red flashing light in bottom right hand corner of xbox 360 arcade console. Says System Error contact customer support error code E 73.
the best thing to do is to contact the customer support because there are many occasions on which it can show you this message and you can't be sure which is which.
hope dis helped you?please rate
Dec 16, 2010 | Microsoft XBOX 360 ARCADE Console
Red light flashing when power button pushed
how many red lights are flashing is their 4 lights all corners lit up or is it 3 red lights with 1 corner not lit up, let me know then i can assist you further
Dec 07, 2010 | Microsoft Xbox 360 Console
My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the Power On LED light.
Pin 1 is for the Positive ( + ) wire.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Aug 23, 2010 | E-Machines T3302 PC Desktop
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
One red light flashing bottom right of the circle no pic or codes
Take a huge hammer and smash the light into pieces. There you go, no more red light...
Dec 25, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
170 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
