Question about Pioneer VSX-D466S Receiver
Pioneer A/V Stereo Receiver - VSX-D466S
Turn off when after ten seconds
there is 3 resistors are burnt, R328,R332,R330, what can cause these to burn out?!
  • 1 more comment
  • b873 Nov 05, 2008
    Does anyone know were i can get a circuit diagram for this model # VSX-D466S Pioneer A/V Stereo Receiver
  • Anonymous Apr 25, 2009
    "power off" message occurs after a few seconds then shuts off.
  • jclarke427 Apr 25, 2009
    after a couple of seconds "power off" message appears then shuts down. We had been away for a week and must have been a power failure as clocks and tape player needed reset.
    Is it worth a repair? Manual suggests cause may lie in the "protection circuit", whatever that is.
    Do you think it's fried?
    Genius:
  • Pioneer Master
  • 1,550 Answers
If they are around the audio amplifier IC maybe are damaged
Posted on Nov 04, 2008
Pioneer vsx-d466s receiver shut down while playing music
Either the power supply went south or one of your amp output stages has been blown.
Sep 10, 2016 | Pioneer Audio Players & Recorders
The value of resistor in the light box color coded
Without a circuit diagram or another actual unit to look at it is very difficult to identify burnt out resistors. Even harder is finding out why it burnt out because most of the time a resistor only burns out if overloaded due to other circuit component faults.
Nov 21, 2015 | Dryers
HOW I FIX MY PIONEER VSX-D466S
Worked fine with the same speakers before? If changed speakers or their wiring, the impedance may be too low now.
Oct 02, 2014 | Pioneer VSX-D466S Receiver
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
Burn Resistor 842 conot find the value
You can get the value of this resistor from the circuit diagram of your model TV.
Usually a burnt resistor is caused by some other component failing that is connected to the resistor.
Apr 19, 2013 | LG Televison & Video
MANUAL FOR PIONEER STEREO RECEIVER MODEL VSX-D901S
Hi
Check the following link. Its athe manual for VSX D 912. May be the same for your one.
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx-d912.html
Ajin
Jan 19, 2012 | Pioneer Audio Players & Recorders
JVC I'ART PRO WILL NOT TURN ON
hi keith, if it smokes a bit leave unplugged and get a engineer to have a look at it straight away good luck
regards
shaun
Nov 27, 2011 | JVC AV-56WP30 56" Rear Projection...
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
Yahoo.comThe a/c switch does not work in any position. 1st 1 & 2 went, then 3, then 4 and finally today 5 went out
1-2-3 WHENT WHEN RESISTOR BURNT OUT
4 ON A RELAY COULD ALSO BE BURNT
5 ALSO ON RELAY THAT COULD ALSO BE BURNT
I ASSUMED THAT THE HEATER FUSE IS OK (CHECH PLEASE)
IF ALL OF THIS IS BURNING UP THE BLOWER MOTOR COULD BE FAULTY
OR THE SPEED SWITCH COULD BE THE CAUSE
LOAD TEST THE MOTOR ON IT'S OWN TO SEE IF OVERDRAWS EXIST
IF NOT CHECK OR REPLACE THE SWITCH
THE RESISTOR ARE KNOWN TO GO
BUT USUALLY THE RELAYS ARE GOOD AND STRONG
THE RESISTOR WOULD BE CLOSE TO BLOWER MOTOR
AND MOST RELAYS ON TOP OF AIR DUCK BEHIND GLOVE BOX
GOOD LUCK
May 26, 2011 | 1998 Chevrolet Malibu
341 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
