Question about LG Washing Machines
LG Intellowasher WM 12225FD Error code 1E will not spin Help please
SOURCE: LG Intellowasher - CL in led code whats wrong?
had this prob too. took me a while to work out. CL is Child Lock... hold down 'Rince' and 'Prewash' buttons at the same time to unlock.
Posted on Aug 13, 2007
SOURCE: LE ERROR CODE ON LG WM-2277HW
It worked!!!!!!!!!!!!!!!This is the second time it happened to me and I had a repair man come out the first time. You need to have a shop vac with you so you can just pull the plug.
Posted on Sep 13, 2008
MNTECH
  • 1543 Answers
SOURCE: lg intellowasher DD 7.5kg WM14225FD error
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Posted on Oct 01, 2008
SOURCE: my lg intellowasher wd1290 error code OE
washer stops with soapy water, code displays OE. Help!!!!
Posted on Oct 19, 2008
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
What causes the EO error message
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 04, 2014 | LG Washing Machines
I keep getting the 1E code. I go into the washer and try and rearrange the load, and want to be able to restart the load but can't do that. Typically it happens when there is only about 10min. left in...
Hello there and thank you for choosing fixya
  • The error code of "IE" signifies a water inlet error. This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on.
  • If every thing there checks out fine then the inlet valve on the machine is faulty and needs to be replaced ...
  • drain error will result in an error code of "OE." This means that your washer is not properly draining. Ensure that your drain hose is free of kinks and clean. Your filter also must be clean
    An error code of "FE" represents an overflow error. This means that the water level is too high, and the machine will start draining itself automatically.
    An error code of "E1" represents a leakage error. This means there is a leak in one of your hose connections.
Aug 04, 2011 | LG WM-2077C Front Load Washer
I get a message le or ue error and machine stops
Where in the cycle is the machine stopping?
A 1E error would be a fill problem. Either the water supply is inadequate (low pressure coming in due to a problem with your water supply), the water supply taps aren't fully open (make sure to open the valves fully), the inlet hose is bent (straighten the hose) or the inlet filter is clogged (clean the filter).
An UE error happens during the spin cycle. Either the load is too small or the load is uneven. Add some items that can tolerate the spin cycle speed or redistribute the load.
A LE error indicates that the motor has overloaded. Wait 30 minutes and then try to restart the machine. If the error persists, the unit needs service.
The manual for the WM-2277H* is available from LG as a DjVu file here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=WM2277HB&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WM2277HB&initialTab=documents&targetPage=support-product-profile# .
I hope this helps.
May 30, 2011 | LG WM-2277HW Front Load Washer
My washing machine had an error code of 1E, and now will not wash on any setting except the "quick wash" - and even then, occasionally the detergent will not go through. It is an LG front...
It is not 1E, but I.E which is "INLET ERROR", the inlet valve is not letting the water through, it does sound intermittent though, please check the following, if it does not solve your problem, the Inlet valve should be replaced (Which can be bought at any reputable Appliance Spares Shop)
- Is the tap open fully?
- Check the Inlet Hose, is it kinked in any way?
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM-2277HW Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
Willnot spin, error code 6e
lg wf-t851 will not spin. displays 6e error code
May 23, 2009 | LG WM-2277HW Front Load Washer
Lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 28, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
146 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
