Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Image gone to #!%
All of a sudden my TV looks like I should be wearing 3D glasses and the image looks fine in the middle of the screen but conclaves out across the edges
  • 1 more comment
  • pigeonde Dec 26, 2008
    Hello, I have this same problem. The TV was just working fine yesterday and this morning, my image seems like I need 3 D glasses. Can you direct me on how to change the convergence ICs if this is the case. Also where can I find those ?
  • charlesk539 Jan 07, 2009
    I have a Sony KP-46WT500 (rear projection TV) and the screen is getting distorted in the upper left hand conner and it seem as if the colors are not mixing properly. The outer edges look a little streached and some spots certain colors stand out more than other, especialy green.
  • vektor Jan 22, 2009
    looks like I need 3-D glasses. Colors are seperated.
  • Sony Master
  • 3,459 Answers
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move the cross up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 30, 2009
    Problem Solver:
  • 4 Answers
Why don't you just get a new "D" board, unhook the wires of the old board and hook them up to the new one. Done with no soldering
you still may have to do a little conv. on the tv, at least thats what I'm doing
Posted on Jan 16, 2009
You need to replace the Convergance ICs STK 392-560(2 of them) in the "D Board".
If you are not a electronic handy man, get assistance from a TV repair tech. This involves de-soldering the IC and soldering back without damaging anything else in the PCB. The ICs are mounted in a heat sink and would require some heat transfer compound to fix it back again. Without the compound, the IC may fail prematurely.
Word of caution :- You are dealing with very high voltage components inside the TV and should be careful before you attempt to repair anything inside the RPTV.
Posted on Dec 30, 2008
  • 10,594 Answers
It is convergence problem and convergence ICs need to be replaced.
If you have basic electronics knowledge and bit experience of big TV repair, let me know to guide you further.
Thank you.
Posted on Nov 04, 2008
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is wavy with the image looking like 3D when you aren't wearing 3d glasses.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Screen image
Go to menu then setup look for convergence if it is not Listed then you have an open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a roll small brown rectrangler looking caps but they are fuses the one in the middle is BAD.This is a $ 225.00 repair job.if done by TV shop.
Aug 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
Hitachi ld328700 picture and colour gone faulty
there was another guy on here that had the same problem and he ended up throwing the tv away because it cost too much to repair, you migt call a repair man in and see what they quote you on yours
Jan 08, 2009 | 2000 Ford Focus
Like a 3D Movie
your convergence has gone out....there is possibley two ic chips that have failed. It might be some fuses but generally if they go the chips are the cause. on average a 300 dollar repair with parts and labor. first try to autoconverge the set if that dont work it will be the chips
Feb 22, 2008 | JVC AV-48WP74 48" Rear Projection...
Toshiba 43A10 projection television
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Toshiba 43A10 43" Rear Projection...
AKAI PT5598HD ghost image the red is offset
Replace STK392-040 IC's with name brand only. No generics.
I use Panasonic brand with no recalls.....Let me know if you
need more help.......................T.
Please rate this solution...........thanks.
Nov 11, 2007 | Akai PT5598HD 55" Rear Projection...
Red ghosts
red convergence went haywire... you need to relace I'm thinking two convergence ICs mounted on heatsink on convergence panel. replace both for usually they both blow replace any burnt resitors too, and hardest of all now you need to reconverge the whole thing.....which is a fine art.....u might be able to do it with the remote ...but u need a manual to go throught the steps really ..but not me i do em in my sleep. take it to shop unless your technical.
Aug 17, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
