42LC55 - LG 42" LCD Fault: TV works for approx 20-30 mins before shutting off. If you try to switch it on again, the ON LED goes Green momentarily then goes RED and then goes OFF. You have to remove the power lead out of the back for 20-30 mins before the TV works again. Then the cycle starts again. I have already changed the Power Assy Board EAY34797001. The fault remains and is the same! ???
techman
  • 3130 Answers
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
  • 231 Answers
SOURCE: Sony KDF-E42A10 cycling on and off
the best thing to first is to replace lamp ..lamp will also cause this..this will be the cheapest route to go first..Please let me kno and I will give you more info or docs from Sony...
Posted on Dec 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
SOURCE: LCD LG42LC55 TV switching OFF
THIS IS CAUSED BY THE MAINBOARD AND NEEDED TO BE REPLACED.
Posted on Nov 30, 2008
SOURCE: Samsung LNT4665FX 46in flat screen
Check out the fixYa solution for the Samsung LNS4051D- it sounds like the same problem. Defective capacitors. You may need different part though.  We just fixed my mom's LNS4051D with that problem. I have the LNT4665 and although it hasn't failed yet, I am tempted to get some capacitors just in case.
Posted on May 18, 2009
I just got a new TV (42 LG LCD), and i was using a 42Panasonic. well since switching TV's my shaw receiver (DCT700) is not working properly. it will work for a couple mins then it stops working and the...
Hi, i wastrying to research about this issue, and yesterday i did all test possible tofix it. I have 2 of these boxes in different TV's and only in one TV is working(32") but in the 42" TV (LG) I'm having exactly same issue.Incredible but by disabling the Energy Saving mode in LG TV the DCT700 worksnormally immediately I activate the ES remote stop working. Try it and let meknow if you resolve this frustrating problem!
Dec 29, 2010 | Arris DCT700 DTV Receiver
42" LCD TV no picture.Have sound
inverter panel is faulty you can probably source another via ebay if your confident on fitting it could be expensive otherwise
Dec 12, 2009 | LG 42LG50 42 in. LCD HDTV
Will not switch on
There's a problem with the video card of the lcd TV  needs replacement .
some chip are damaged .or gets over heated eg processor .
Good luck
Oct 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Nov 04, 2008 | LG 42LC2D 42 in. LCD HDTV
TV sound to Cinema system?????????????
Thi is not possible so I exchanged the TV for another one, This TV does not have AUDIO OUT function.
Mar 28, 2008 | Panasonic Audio Players & Recorders
LG 42lc7d 42" lcd
Replace power supply and this should take care of all of you problems part number is EAY34797001.
Josh
Feb 09, 2008 | LG RZ-20LA70 20 in. LCD Television
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
