Question about Samsung SGH-a737 Cellular Phone
Locking/Unlocking phone The outside part of my phone used to lock when it was closed and you had to hit "Unlock" and "Ok" to be able to use the outside buttons or you could slide it open to unlock it. My son was playing with my phone and now it will not lock when it is closed. I want it to lock so when I put it in my pocket, it doesnt allow buttons to be pushed. How do I fix this?
  • nikkijay21 Nov 08, 2008
    I tried all the settings and all the lock settings. Nothing has worked :(
  • 24 Answers
Try to look at the settings(phone settings)
Posted on Nov 08, 2008
  • Angelo29 Nov 08, 2008
    Try to restore factory settings.
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Dec 12, 2015 | Renault Megane Cars & Trucks
I just unlocked a blackberry 8100 from t mobile to use on the att network and the t mobile sim still works with my phone however when I put the att sim card into the blackberry I get a message on the phone...
It hasn't been unlocked, try again and follow these instructions:
Model : T-mobile BlackBerry Models
1 – On the Home screen, click the Tools icon. The Options screen appears.
2 – In the tools screen, select the Settings icon.
3 – Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 – Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 – Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 – Input the Network Unlock code
7 – Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 – While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 – Choose “Advanced Options”.
3 – Select “Sim Card”
4 – There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 – Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 – Input the SIM Unlock code
7 – Press in the trackball in once
Your phone is unlocked
Jun 25, 2010 | RIM BlackBerry Pearl 8100
Problem The rear hatch door will not unlock.
First, on the rear hatch, there is an actuator. On FX, when you close the trunk, it kind of **** the hatch closed all the way. When you press lock on the remote, this same actuator locks it as well.
1) when you unlock the car from the inside, go back there and press the button to open the hatch door manually, do you here any noises?
2) Close all doors, go back close to the hatch button and using the remote , lock the car and then unlock the car. you should hear a sound from the actuator locking and unlocking the lock on the rear hatch!
If you don't hear this, your actuator is inop.
Next step would be to check the fuses inside the car, on the left bottom driver side, and outside on the battery compartment.
It might be just a fuse.
If all fuses check ok, your actuator is most likely gone! Not ea expensive fix, just time consuming!
NOW, if you can hear the noises, then something is either broken inside the actuator or one of the cables is loose!
Hope that helps.
Also, what year and miles on your fx?
Oct 20, 2009 | 2004 Infiniti FX35
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Envy 2 dials phone numbers accidentally- need to set key guard
On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
Dec 03, 2008 | LG enV VX9900 Cellular Phone
ENV2 Keyguard Lock problem
When your phone is closed, hit OK for the menu, then hit 6 for Keyguard Settings. There, you can not only change the time it takes for the keyguard to automatically go on, but ALSO change the keyguard unlock options from One Step Unlock (just hitting ok) to Two Step Unlock (hitting ok then clr). It's not a 4 digit code, but it's a lot better than just hitting ok, and much more time efficient than locking your phone every time you put it in your pocket.
Oct 21, 2008 | Verizon Communications enV2 Cellular Phone
Programming keyless remote
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
EnV2 keyguard
I just called Verizon about the keyguard being too easy to unlock and they were clueless. But here's a solution: As above, using the OUTSIDE keypad, click OK, go down to keyguard settings (number 6), then hit unlock options (number 2). This gives you the option of using a one step unlock process (hitting the OK key) or a two step (hitting the OK then the Clear). I think it is still too easy to accidently answer the phone but at least this will cut down on the dialing.
Jun 22, 2008 | LG enV VX9900 Cellular Phone
Samsung SGH-a737 Cellular Phone Logo
102 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
