posted by cabana on Oct 04, 2006
The picture and sound suddenly has a lot of interference
and then goes off. It acts as if there is a loose connection. We can get the picture and sound back temporarily by jiggling the cable in the back of the TV. Replaced the cable but did no good. Thank you.
Solution #1
posted on Oct 04, 2006
You already hit the nail in the head,the problem might be the actual conector loose inside the set or the tuner has loose conections to the main board,the shell of the tuner is the ground make sure the conections are solid,if you are familiar with tv service this will help but if you are not too familiar be safe and call for help,right now it should not be expensive.
Comment by jomaru, posted on Oct 04, 2006
The conector can not be loose in any way,sometimes is part of the tuner and sometimes is conected to an isolator and then to the tuner,if it is part of the tuner it solders right to the tuner and the solder has broken inside too.Satay in touch if you need more help.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Panasonic PV-C1321 13 in. TV/VCR
Email this problem
Email this problem
Can you Help with these TV Combos problems?
Panasonic PV-C1321 13 in. TV/VCR Combo
codes for remote
codes for remote
hello I have tv remote. R-25B03... Answer This...
VCR Tape stuck and I can't...
VCR Tape stuck and I can't... Answer This...
program timer
program timer
The program timer in my tv-vcr... Answer This...
Washed out picture
Washed out picture
Soon after warranty was out... Answer This...
Panasonic VCR ejects wont play...
Wont play ejects after loading... Answer This...
Repair Service
Find TV Combo Repairman Near You:
