Question about Hitachi 43FDX01B TV
Hitachi43fdx01b had convergence issues, now screen is dead
Tried a convergence adjustment but I made it worse and the set crashed.
  • enterkine Nov 04, 2008
    I have a Hitachi 43fdx01b that had a problem with the red convergence, I tried toadjust the convergence with remote control, now the set has crashed and the picture is out . Can anyone tell me what I should do?
  • Hitachi Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TVhitachi43fdx01b had convergence issues, now screen - 2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 08, 2010
I will like to try to fix my sony projection tv model #: KP-65WS500 from a blue dowble images
it could be either the blue CRT being bad since the set shut down after turning blue. It could also be the convergence needs replacement. The CRT sounds more likely you can get the replacement Blue CRT and also the sony #1 convergence repair kit from www.tvrepairworld.com they can also assist to determine which of the two is most likely causing the issue.
Apr 04, 2012 | Sony KP-65WS500 65" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Replaced convergence board, but can't adjust convergence
Bad chips or faulty soldering....
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jun 10, 2009 | Zenith R40W46 40" Rear Projection...
Cant adjust the blue its all over screen its a hitachi 65s500
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 02, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
Distorted image & colors: Hi there I have a sony bravia VPL AW15 with about 140 hours of lamp usage. My problem is that all of a sudden the image is distorted, the letters show in red (3d like effect) and...
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
  • Screen looks 3D
Mar 01, 2009 | Sony KP-53HS30 53" Rear Projection...
Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
  • Screen looks 3D
Feb 25, 2009 | Philips 60PP9363 60" Rear Projection...
The screen has blue green green, red outlines how do i fix it
This might be a convergence issue. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That sight pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged.
Feb 19, 2009 | Sony KP-57HW40 57" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony 51 in Rear Projection Convergence Issues...
U have serious convergence board issues. If the solder connections on board go, that will definitely cause the hassle. If you are handy you can remove the convergence board and reheat every ****** connection on that board. Or if you check out google you can carefully put the board in an oven and use the bake setting for about 8 minutes at a temperature I forget.
May 03, 2017 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 43FDX01B TV Logo
171 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
